Allin1DC VFD wiring
routebot
Allin1DC VFD wiring
Post by routebot »
Im working on a knee mill CNC conversion. I connected the some of the wires but, I'm not sure about the rest. The VFD doesn't use the same labels as Centroid. Looking for clarity. Thanks!
Centroid_Tech2
Re: Allin1DC VFD wiring
Post by Centroid_Tech2 »
These connection points called out are for the OAK board, but the wire numbers and colors will match.
routebot
Post by routebot »
Thanks for the correct wiring diagram. I assume the remaining 5 wires are not used. Correct?
Optionally, you could jumper YEL from R1 to DOC, then connect WHT/BRN from DO3 to INP12 on the Allin1DC.
That would give you a "spindle zero speed" signal, which can be useful in some situations.
However, on a knee mill with no PLC control of the drawbar and with no automated gear shifting, you probably don't need it.
