Virtual control panel not showing up <resolved, use USA Windows Format>
New install virtual control panel does not show up on screen it shows in taskbar that it is running A black vertical line shows up in the middle of the screen Will this work with a 17 inch monitor
Re: Virtual control panel not showing up
Craig...
Check that your video drivers are up to date. I am running it on a 15, 19 and 21" monitor
I’ll check them tomorrow thank you
Make sure you're using a 16:9 monitor, not 4:3. It runs but will not show up on a 4:3 unless your system has an option for that A/R & it will have "letterboxing." Don't ask me how I know this.
Milton in Collierville, TN
Re-say display settings the Control panel is showing up now but it’s in the middle of the screen any suggestions
Can you post a picture? Is your monitor wide screen/16:9 or 4:3
Clay
near Winston-Salem, NC
I can move it now open cnc 12 it comes up in the middle there is a blank on the right-hand side for it I can go to the taskbar open a file go to the top drag it over to the split screen the control panel will pop up click on it and I can put it over where it belongs I think it’s a Windows problem I have a bigger screen coming I will be at will fix the problem thank everyone for the help Don’t know how to send a pic
I saw this when windows was set to "tablet mode"
make sure to not have that activated.
and be sure to follow the windows 10 setup video for all of the rest of windows 10 tweaks!
Are you using a WIDESCREEN monitor? (16:9 aspect ratio)? Or an old square monitor? If the latter, that's likely your problem.Craig Hilliard wrote: ↑Fri Feb 16, 2018 5:22 pm New install virtual control panel does not show up on screen it shows in taskbar that it is running A black vertical line shows up in the middle of the screen Will this work with a 17 inch monitor
No, but I have one ordered, hoping this will fix problem. Thanks for all the help.
