Fusion 360 Mill Post Processor for CNC12 with additional Features (New Community Version 1.0)
Re: Fusion 360 Mill Post Processor for Acorn with additional Features (New Version 5)
You could always throw in in a cnc simulator. But generally G-code is pretty simple. if you see junk it is generally something like what you expirienced.
- CNC Control System Serial Number: 20D7787C3C66-0826226485
A couple of questions regarding coolant options - I've recently begun using the mist command in addition to the flood command and have been choosing "Flood and mist" from the coolant dropdown in Fusion. HOWEVER it appears that no coolant commands are being written to the .nc file. When I was just using "Flood" an M8 command was being written. It appears there's a case statement for the coolant in the .cps file, but I'm not sure what the case conditional would be called for "Flood and mist"... Anyone have any ideas? I'm also not sure if that's the only snippet of code I'd need to add...
ALSO, because I've been using the flood and mist together I've had to activate them manually in CNC12, but sometimes it complains about the manual coolant activation and prompts me to change it back to auto before it will progress with the .nc file and therefore no flood or mist is possible...
Thanks in advance for any help!
I've posted a new version 5.2 of the PP at the bottom of the first post that includes some recent fixes:makemake wrote: ↑Tue Aug 27, 2024 4:49 pm A couple of questions regarding coolant options - I've recently begun using the mist command in addition to the flood command and have been choosing "Flood and mist" from the coolant dropdown in Fusion. HOWEVER it appears that no coolant commands are being written to the .nc file. When I was just using "Flood" an M8 command was being written. It appears there's a case statement for the coolant in the .cps file, but I'm not sure what the case conditional would be called for "Flood and mist"... Anyone have any ideas? I'm also not sure if that's the only snippet of code I'd need to add...
- Rigid Tapping fix from Uwe (suntravel)
- Clamp M10/M11 fix. An M11 was added to the post even when the Property "Enable Clamp On/Off" was not selected
- Support to enable Flood and Mist Coolant at the same time (a M7 and M8 will be added to the G-Code)
1 user liked this post
cool, thanks, i changed this thread to a sticky post.
Just to confirm.... This newest post works with Rigid Tapping, but NOT rigid tapping with chip breaking?
I modified the post processor to add machine simulation. It basically involved copying some code from fusion and putting it inside. Other than that i have not modified the post code other than adding this.
File is attached, feel free to merge
Changes according to : https://www.autodesk.com/support/techni ... cavq1.html
- Centroid_Mill_MinRev-40783-swissi-005.2 + Spikee mod.zip
- Swissi post processor with machine simulation added
- (22.92 KiB) Downloaded 14 times
Very cool
Thanks. That is very nice.
With respect to rigid "tapping with chip breaking", here is the error message you get (see attached). I am just starting to learn gcode so this is a bit above my pay grade.
Thanks... Richard
Thanks... Richard
Sounds like a simular issue:
https://forums.autodesk.com/t5/fusion-m ... p/10859616
Perhaps the solution works
That is not working with Centroid.spikee wrote: ↑Wed Jan 01, 2025 7:38 pm Sounds like a simular issue:
I made a mod that makes Peck Tapping in fusion like the output from Intercon
case "tapping-with-chip-breaking": // Uwe Peck Tapping
if (!F) {
F = tool.getTappingFeedrate();
writeBlock(
gAbsIncModal.format(90), gCycleModal.format(84),gRetractModal.format(99),
"X" + xyzFormat.format(x),
"Y" + xyzFormat.format(y),
"Z" + xyzFormat.format(cycle.stock - cycle.incrementalDepth),
"R" + xyzFormat.format(cycle.retract),
conditional((P > 0), "P" + secFormat.format(P)),
pitchOutput.format(tool.getThreadPitch())
for (var i=2;((cycle.stock - cycle.incrementalDepth * i)>(cycle.depth * -1));++i)
if ((cycle.stock - cycle.incrementalDepth * i)>(cycle.depth * -1))
writeBlock(
"Z" + xyzFormat.format(cycle.stock - cycle.incrementalDepth * i),
writeBlock(
"Z" + xyzFormat.format(cycle.depth * -1),
gRetractModal.format(98)
break;
