NEEDING HELP REGARDING CIRCUIT BOARD PARTS
KEITH_TSE
CNC Control System Serial Number: OAK: 104625, CPU7: 20295
Post by KEITH_TSE »
Control S/N: 20295
We’re adding an auxiliary limit switch to a fixture that resides on this machine.
I’m kind of new to circuit boards, but it looks like I need a couple of terminal blocks and some jumpers to move forward with the installation.
Which terminal block and jumper do I need to order to fit on the highlighted locations?
How do I choose what I need? There are a ton of different configurations, and I’m confused about what to order.
Does Centroid sell these parts?
Thanks a ton.
Photo album link:
K0400067.pdf
(473.3 KiB) Downloaded 6 times
report.zip
(74.32 KiB) Downloaded 4 times
spikee
Re: NEEDING HELP REGARDING CIRCUIT BOARD PARTS
Post by spikee »
Centroid can tell you which counter part you need.
centroid467
Post by centroid467 »
So, the DC3IO should have been shipped with the jumper blocks for J11, J12, J13, and J14. These are common parts but since we have a sell price for them, I think we can sell you some. Our part number for those jumper blocks is 1761.
H12 is a connector that requires crimping. Our part number for the requisite 8 pin housing is 1295 and the terminals is 1477.
KEITH_TSE
Re: NEEDING HELP REGARDING CIRCUIT BOARD PARTS - RESOLVED
Post by KEITH_TSE »
Purchased from Centroid the above part numbers and an additional pre made cable #10400. Everything fits where it needs to, except the 1477 terminals in to the 1295 housing. However, I am relatively new to this and could be missing something.
Thanks for the help!
centroid467
You'd want to crimp the wires on using a CST-100 series compatible crimper and then they push to insert into the housing.
spikee
Post by spikee »
FYI there are these universal crimpers on amazon and the likes, that split the single crimping action into two. So a more universal tool can be created.
