Rigid Tapping parameter 78 ?
diycncscott
Re: Rigid Tapping parameter 78 ?
Post by diycncscott »
I'll look into it. You should not be receiving that message as your report indicates you definitely have Pro.
I apologize for the inconvenience.
cut2cut
CNC Control System Serial Number: 38D26950ABAB-1221170383
Post by cut2cut »
diycncscott wrote: Thu Feb 15, 2018 7:37 am I'll look into it. You should not be receiving that message as your report indicates you definitely have Pro.
I haven't connected my computer to the internet since before I started using the software. Perhaps this is an issue ?
Jake
diycncscott
No it isn't. Please pm me with your email
cut2cut
Post by cut2cut »
Perhaps I can narrow the error down to one of the parameters changes tonight. Previously I had tried rigid tapping but only changing , I believe, 78 and maybe perhaps 36 too, I don't recall, but I didn't see the error until I made further changes to the many parameters suggested in the draft document ? The draft document for rigid tapping suggests changing parameters 36,37,68,69,74,78,82,84,240,241,149. So through trial and error I can go through those to put them back to their original settings which I should have from a previous report file.
Jake
cut2cut wrote: Thu Feb 15, 2018 4:57 pm
Jake
Did you send Scott a PM (private message) with your email address?
Click on his name and it should take you to that window.
cut2cut
Post by cut2cut »
[/quote]
[/quote]
Yes, thanks Marty. I have. Perhaps he will figure it out before I try the above. I was just giving more details to work with. So far I haven't received an email.. he is probably looking for a solution, still.
Best Regards,
Jake
cut2cut wrote: Thu Feb 15, 2018 5:14 pm
[/quote]
Best Regards,
Jake
[/quote]
Scott starts super early and leaves early. You may hear from him tomorrow. He is worth being patient and waiting for direction from.
cut2cut
Post by cut2cut »
martyscncgarage wrote: Thu Feb 15, 2018 5:16 pm
[/quote]
Thanks for the heads-up regarding his schedule . btw, I believe he asked for my email so he could fix a different issue I was having with my account here on the forum. I had asked a moderator and now notifications are working properly since I sent the email address.
Jake
axmem
CNC Control System Serial Number: MILL 38D2693D0B0-0110180508 LATHE 38D2694DA013-0321180756
Post by axmem »
Hi there.
I have exactly same issue. Does anybody know how to get it sorted?
diycncscott
Working on it. Send me a pm with email.
