Feed Rate
JWH
CNC Control System Serial Number: 0309214470
Feed Rate
Post by JWH »
I built a diy cnc router and have everything working properly. No matter how much I change the "F" gcode setting on a job the feed rate is extremely slow. Exactly what controls the job feed speed rate with the acron12 router control software. As an 80 year old here I need the answer to be straight to the question.
Re: Feed Rate
There is no short answer because the problem could have many root causes.
pls. post a report, so we can help you.
Re: Feed Rate
And a copy of the g-code file giving you problems.
JWH
Re: Feed Rate
Post by JWH »
It appears the feed over ride was not correctly set so now the feed speed can be changed within the g-code.
Re: Feed Rate
NeonVortex wrote: Mon Nov 04, 2024 3:37 am I want to see how you solve the problem
I suppose he set feed rate override back to 100%
