Dot size
JimN
CNC Control System Serial Number: 0CB2B7D670CB-0603203367
Dot size
Post by JimN »
I just upgraded to acorn 5.1 and am wondering if there is a way to control the size of the tracing dot on the graph while running a job. It is currently quite large and obstructs the adjoining lines
Jim
Gary Campbell
Re: Dot size
Post by Gary Campbell »
Decrease the size of that tool number in your tool database
CNC Depot Modular ATC kits
Re: Dot size
JimN wrote: Wed Oct 09, 2024 4:44 pm I just upgraded to acorn 5.1 and am wondering if there is a way to control the size of the tracing dot on the graph while running a job. It is currently quite large and obstructs the adjoining lines
Jim
the 'dot' is a representation of the tool diameter being called and used by the g code program.
so if the g code is using tool #1 CNC12 looks up the tool diameter in the tool offset library for tool #1 and make the dot that size.
JimN
Re: Dot size
Post by JimN »
Thanks guys for your quick response. I did research for answer pertaining to this but couldn’t find anything. Did I miss something?
Jim
