plc programming
curiousMike
plc programming
Post by curiousMike »
How to go about finding someone who I could hire to make changes to the plc program? I simply wish to add 3 relay outputs that mirror the on/off state of the inputs 6,5,4 . All I need is someone to add the code to the standard .src file for acorn 12. Highlight the changes and I can do the rest. Preferred payment method would be a PayPal transfer.
Houseman303
CNC Control System Serial Number: A901313
Re: plc programming
Post by Houseman303 »
Hi, Marc from cncsnw can program the plc for you. fair prices.
Re: plc programming
Yes, I could do that. PM me if interested.
Also, post a report here, and tell which three outputs you want to use for this purpose.
A report is necessary because "acorn 12" does not tell me what version of CNC12 you are using; nor whether your Acorn is on a mill, lathe, router or plasma table; nor what outputs you are already using for other purposes.
curiousMike
Re: plc programming
drop me a note at msm@mvero.com. we can work somet
