10-22-24 UPDATE! CNC12 v5.20 has been released Mill, Lathe, Router, Plasma is now available for public testing.
Allin1Chris
PLC Expert
Re: Centroid CNC12 v5.19 rev3 BETA CNC software is now available for public testing
Post by Allin1Chris »
Sword wrote: Sat Aug 10, 2024 1:07 am I see that the "Axis Drive Type" configurations show none of the usual I/O information and thus does not load any of the I/O info that was previously saved with a drive type. Is this intended or a temporary bug? ;)
In fact, a quick comparison of an old drive type .xml and a new one shows a lot of info is missing or omitted. Old file is 353 lines whereas the new is only 59 lines.
The I/O Information and Drive Information were separated into 2 different presets. For this particular revision, the I/O preset screen was hidden, but should appear in the next revision.
Separating them is useful for when you use different drives but use one standard i/o layout.
Centroid PLC Tutorial Videos
Sword
Post by Sword »
ASPeters wrote: Mon Aug 12, 2024 8:37 am
This is a new file that has to be added called "user_language.msg" which can then be moved from version to version without having to edit language.msg everytime we put a new build out.
Thanks for this! That took care of the last three that I couldn't change on the main menu with the language.msg file. Nice that it's portable too!
Call me anal, but that looks better. :lol:
Scott
Sword
Post by Sword »
Allin1Chris wrote: Mon Aug 12, 2024 9:12 am
Gottcha, thanks for the explanation.
Scott
Allin1Chris wrote: Mon Aug 12, 2024 9:12 am The I/O Information and Drive Information were separated into 2 different presets. For this particular revision, the I/O preset screen was hidden, but should appear in the next revision.
What's the file name for the I/O information? Is it another XML file? I'd like to add this file to the script I use to copy out all important machine parameters. The I/O info in a single file saves a lot of time on new installs.
Sword wrote: Mon Aug 12, 2024 1:16 pm
Completely different meaning in German :lol:
But yes, it looks better for me also.
RC-Lights
CNC Control System Serial Number: 0008DC111213-1005220061
Post by RC-Lights »
hi all,
i udated to the new 5.19rev3 Beta. Installation was okay, but after setting the wizzard i got an error-message:
most of the settings i did are not working. i opened a wizzard and tried again, without succes.
Machine is not useable right now. any ideas, if maybe i did something wrong ?
Report is attached.
best regards,
Michael
report_0008DC111213-1005220061_2024-08-13_12-24-51.zip
(972.82 KiB) Downloaded 5 times
friolator
Post by friolator »
suntravel wrote: Tue Aug 13, 2024 3:10 am Completely different meaning in German :lol:
Same meaning, but in (at least American) English, it's shorthand for "anal retentive" -- as in, extremely fussy.
Allin1Chris
PLC Expert
RC-Lights wrote: Tue Aug 13, 2024 6:42 am hi all,
Report is attached.
best regards,
Michael
Thanks for pointing this out, attached is a quick fix for you. Extract the contents of the .zip into your C:\cnct directory and overwrite. This issue will be resolved in future revisions.
VacuumHoldDownFix.zip
(230.21 KiB) Downloaded 7 times
RC-Lights
Post by RC-Lights »
Allin1Chris wrote: Tue Aug 13, 2024 9:48 am
Report is attached.
best regards,
Michael
Thanks for the Quick Support, is working now!
Michael
Sword
Post by Sword »
Ah yes, the pitfalls of an international crowd. :oops: :lol:
Scott
