How to implement one shot lub. automatically
Black Forest
Post by Black Forest »
How would I go about implementing in a program for my one shot lube system to be triggered say at 5 or 10 minute intervals? This would be using a relay to trigger a 24v solenoid valve.
Re: How to implement one shot lub. automatically
I would setup the Lubetimer in the wizard.
Black Forest
I looked in the wizard and only found an output label lube pump. I looked in the manual but didn't find anything. Would you please tell me more?
I will figure it out tomorrow.
I have no automatic lube on my machines, but a lube timer is even an example in the PLC manual.
We will get it going on your mill.
Black Forest
I have been looking for the PLC manual but haven't found it.
Black Forest wrote: Sat Aug 10, 2024 2:16 pm I have been looking for the PLC manual but haven't found it.
Here it is
My main guide for complete confusion 🤣🤣
Black Forest
If I would set par# 179 to 1010 would that turn the pump on and off every 10 minutes or just after the first 10 minutes?
Every 10 min runtime MDI or job for 10s
Related reading
https://www.centroidcnc.com/dealersuppo ... ds/171.pdf
