CNC12 Router v5.20 is now available
tuffduck
Re: CNC12 Router Restructure Beta Software thread. RC2 Now available, July 23rd
Post by tuffduck »
I noticed the incremental movement for each axis has been either moved or removed. What is the recommended work around?
suntravel wrote: Thu Jul 25, 2024 11:39 am Sure, no deal to make it work, but even Intercon on a router is posting M7 if Mist is selected in the tool lib.
This one shortcut misusing M7 for Dust has a long rattail now.
If it is changed correctly to maybe M107, lots of users will curse Centroid because they have to change something :lol:
IMHO the best bet is to stay with ISO 6983 for all basic functions.
I'll admit I've never used Intercon and have no need to or plans to so maybe I'm not the best person to comment then. :D
tuffduck
Post by tuffduck »
Trying to find this screen.
Chapter 6.6 in the manual
tuffduck
Post by tuffduck »
F1/Setup -> F4/Feed -> F2/Inc
tuffduck wrote: Thu Jul 25, 2024 8:33 pm I noticed the incremental movement for each axis has been either moved or removed. What is the recommended work around?
- most use MDI to do this.
- the menu's have been moved
F7 Utility, ---> F4 Power Feed
- we are working on a CNC12 Router Operator manual.
Boatwrights Workshop
CNC Control System Serial Number: E062347948F9-0324225805
Re: CNC12 Router Restructure Beta Software thread. RC3 Now available, July 29rd
Post by Boatwrights Workshop »
Will there be a revised manual for the new features, especially for the "Configuration Wizard? I would like to a brief explanation of how to configure these screenshots I have posted? I have tried the "Touch Plate" configuration but I get a notice saying it's not setup correctly even though my tool touch off is functionable in Input #7.
Blue Elephant 1318-4th axis Rotary, 6hp Spindle with Richauto B58 DSP controller converted to Centroid Acorn, Shopbot Desktop 2418 with 1.25hp HSD Spindle
Epilog Helix 50 watt C02 laser 18"x 24" work area
Graphtec FC8000-30" Vinyl cutter/Plotter
Software: Vectric Aspire 12.0v; Rhinoceros 8 with RhinoCAM 2018; Deskproto 8.0v; Autodesk Artcam Premium 2018; CorelDraw 2020; FlexiSign Pro 10.5v
Boatwrights Workshop wrote: Mon Jul 29, 2024 6:02 pm Will there be a revised manual for the new features, especially for the "Configuration Wizard? I would like to a brief explanation of how to configure these screenshots I have posted? I have tried the "Touch Plate" configuration but I get a notice saying it's not setup correctly even though my tool touch off is functionable in Input #7.
yes we are working on a CNC12 Router Operator manual.
for now just post your question on the forum and we'll do our best to answer it.
and you'll have to post a fresh report.zip so we can see your setup. thanks!
are you confusing a Tool Touch off (aka TT used for setting tool lengths) with a Surface plate typically used to set part zero?
