Denford Triac Carousel ATC
Re: Denford Triac Carousel ATC
yeah that one!
you can probably do this ATC with just a macro. i'm in the middle of several projects at once :D , so hoping someone else can jump in here and give you some specific guidance.
Chaz
Post by Chaz »
OK thanks.
I know there is a lot of documentation and effectively a fairly complex eco system for us who are not too familiar with it. Is there a 'cheat sheet' that shows the depedancies on how each system works together? For example, it would be nice to see something like this (perhaps an image) ....
1. PLC.MAP is where we define all inputs / outputs. If you need new ones, put them in here and use this guide (link) on how.
2. ABC Macro is written like this (guide) and it will use the inputs / outputs defined in PLC.MAP
3. Mill.SRC is the main source file where XYZ happens and it will look at the PLC mapping and use the ABC Macros to execute based on certain M Commands which are defined here (guide).
etc
Chaz
Post by Chaz »
cnckeith wrote: Wed Jun 19, 2024 5:53 pm yeah that one!
I did do a Macro years ago (on Centroid) for an early Lathe Rachet / Pawl system which then discovered a bug which was since fixed. The 'method' is probably no longer the right way to do it but I did look at that again yesterday. That was entirely Macro based (I think).
Let me see if I can work out how to do the same again for this application and start from scratch.
I know there is a version of Centroid that we can install to test stuff but not sure if there is a version that I can emulate without being at the machine all the time? That said, I've got wifi dongle coming later today, once I get teamviewer / similar installed, that should hopefully allow me to test from my office.
Chaz wrote: Thu Jun 20, 2024 4:58 am
no the PLC is on the main board so you need to be connected to a board
Chaz
Post by Chaz »
OK. With 2 screens, loads of docs, I'm getting the jist of this. One part where I am stuck is the definition of
;M80_SV IS SV_M94_M95_80 ;Carousel In
;M81_SV IS SV_M94_M95_81 ;Carousel Out
When the M6 Macro runs, it has a part where it says:
M94/80 ;Request Carousel In
Where / how is the 80 defined? How is the carousel in mapping aligned to this? IE, where / how does it know what output to trigger? Outputs are defined up top in the macro but commented out. I've edited mine to match this system, so may not be correct based on the original macro. I've added in Outputs for myself as I find it odd that Inputs are shown, but not Outputs.
;Inputs
;ZeroSpeed is on INP12
;OrientComplete is on INP17
;ToolClamped is on INP21
;ToolUnclamped is on INP22
;CarouselIsIn is on INP34
;CarouselIsOut is on INP35
;Outputs
;ATC_CarouselIn is on OUT33
;ATC_CarouselOut is on OUT34
;ATC_CarouselForward is on OUT35
;ATC_CarouselReverse is on OUT36
;UnclampTool is on OUT37
If I look at the .src document, I can see some code that explains Carousel In / Out.
;------------Carousel In/Out Section------------------------
;Carousel In
IF (SpindleIsOriented && M80_SV && M6_SV) || M80_SV THEN RST M81_SV, SET ATC_CarouselIn,
SET CarouselInOutTimer_T, SET MovingCarouselIn_M, RST MovingCarouselOut_M
IF SV_STOP || !SV_PROGRAM_RUNNING || (MovingCarouselIn_M && ATC_CarouselIsIn)
THEN RST ATC_CarouselIn, RST M80_SV
IF ATC_CarouselIsIn THEN (CarouselInState_M)
Is there something here that helps define or is this just a process / set of state checks?
Or ....
Is the mapping automatically taken from what's defined via the Wizard and it knows that for example ATC_CarouselIn is mapped to OUT33 and it will then basically interpret that as:
M94/80 (or in other words) M94/ Activate Output 33?
Greg
Post by Greg »
While memory bits are the preferred way to do things I also used simple input/output commands to the pre-configured file and it works perfectly fine too. Here is my frankenstein mfunc6, it has performed thousands of tool changes without a problem.
; Filename: mfunc6.mac
; Description: Tool Change Macro
; Notes:
; Requires: CNC12 V5.04
; Revision Date: 14 JUN 2023
; Please see TB300 or the following link for tips on writing custom macros.
; https://www.centroidcnc.com/centroid_diy/downloads/acorn_documentation/centroid_cnc_macro_programming.pdf
; Parameters:
; #9011 = Probe Input
; #9044 = TT Input
; #9160 = Enhanced ATC Features (Bins)
; #9161 = Maximum Tool Bins
; #9431 = 0 : Hole Style Holder
;         1 : Fork Style Holder
; #9432 = 0 : Fixed TT Position
;         1 : Surface Plate
;         2 : Tool Library
; #9433 = Surface Plate WCS Part 0
; #9830 = ATC Type, 0 = None, 1 = Carousel, 7 = RackMount
; System Variables:
; #4003 = Positioning Mode (G90/G91)
; #4120 = Requested Tool
; PLC Variables:
; ToolUnclampedState_M IS MEM12 (#70012)
; SpindleOrientedState_M IS MEM13 (#70013)
; SpindleZeroSpeedState_M IS MEM14 (#70014)
; AirPressureLow_M IS MEM15 (#70015)
; ToolChangeComplete_M IS MEM52 (#70052)
; AtPutbackLocation_M IS MEM59 (#70059)
; AtRequestedToolLocation_M IS MEM64 (#70064)
; CarouselInState_M IS MEM74 (#70074)
; CarouselOutState_M IS MEM75 (#70075)
; PutBackPosition_W IS W50 (#96050)
; User Variables:
; #101 = Saved Positioning Mode (G90/G91)
; #106 = Tool Touch Height
; #107 = New Tool Request Bin Location
; Return Points:
; G28 = Used For ToolCheck Position / M25 Home Positions
; G30 = Used for Z Height Flyover
; G30 P3 = X,Y,Z TT Location
; tt_check_configuration.cnc:
; #33001 = Tool Touch Input (Value from P11 or P44)
; #33002 = Fast Probe Rate
; #33003 = Slow Probe Rate
IF #50001                        ;Prevent lookahead from parsing past here
IF #9006 == 0 THEN GOTO 950      ;Perform Default Macro if ATC not Installed
IF #9830 == 1 THEN GOTO 600      ;Jump to Carousel Section of Macro
IF #4120 == #9976 THEN GOTO 1000 ;Skip macro if requested tool is in spindle
IF #9160 > 0 THEN #107 = #[#4120 + 17000] ELSE #107 = #4120
IF #107 > #9161 THEN GOTO 800    ;Error Tool Change on Invalid Tool
; Carousel Tool Change Program Starts
N600
#101 = #4003                     ;Save Positioning Mode
M109 /1/2                        ;Disable Overrides
M5                               ;Disable Spindle
M9                               ;Disable Coolant
M107                             ;Send PLC Tool Number
G4 P.25
G30 G91 Z0                       ;Move Z to tool change position
G90
M94 /7                           ;Request Tool Change
M101 /70014                      ;Ensure Spindle at Zero Speed
;IF !#70013 THEN M19              ;Orient Spindle
;M101 /70013                      ;Confirm Spindle Oriented
M101 /50037                     ;Drawbar air pressure above 120psi
IF #96050 == 0 THEN GOTO 650     ;Skip putback
; Carousel Tool Putback Section
M101 /70059                      ;Wait for carousel at Putback Position
G4 P.25
;Move Carousel in and Unclamp Tool
M101 /70059                      ;Ensure carousel at Putback Position
M94 /62                          ;Request Carousel in
M100 /70074                      ;Wait for Carousel In
G4 P.5                           ;Carousel debounce
G4 P1.5
M15                              ;Unclamp Tool
;M101 / 50044                     ;Check if drawbar is unclamped
; Carousel Tool New Tool Section
N650
G4 P1
G53 Z0                           ;Raise head to Clearance
M94 /40                          ;Set PutBackComplete
M101 /70064                      ;Wait for carousel at Requested Tool Position
M95 /40
;IF !#70012 THEN M101 /70013      ;Confirm Spindle Oriented if not Unclamped
M100 /70074                      ;Wait for Carousel in
IF !#70012 THEN M15              ;Request Unclamp if not already
M101 /50044                      ;Check if drawbar is unclamped
M94 /61                          ;Airblast on
G30 G91 Z0 L30                   ;Move Z to tool change Position
G90
M95 /61                          ;Airblast off
M16                              ;Clamp Tool
M100 /50044                             ;Check if drawbar is clamped
;M5                               ;Turn off spindle and orient request
; Carousel Finish Section
M95 /62                          ;Request Carousel Out
M100 /70075                      ;Wait for Carousel Out
M101 /70052                      ;Wait for Tool Change Complete
M95 /7                           ;Reset Tool Change Request
M108 /1/2                        ;Enable Overrides
GOTO 900
N800 ;Errors
M225 #100 "Invalid Tool Requested\nCycle Cancel to Abort"
GOTO 800
N900 ;Restore Modes
G#101 ;Restore Positioning Mode
GOTO 1000
N950
M6
N1000                            ;End of Macro
Chaz
Post by Chaz »
Greg wrote: Thu Jun 20, 2024 2:19 pm While memory bits are the preferred way to do things I also used simple input/output commands to the pre-configured file and it works perfectly fine too. Here is my frankenstein mfunc6, it has performed thousands of tool changes without a problem.
; Notes:
; Parameters:
; #9044 = TT Input
;         1 : Surface Plate
;         2 : Tool Library
; System Variables:
; PLC Variables:
; User Variables:
; Return Points:
N600
M5                               ;Disable Spindle
M9                               ;Disable Coolant
G4 P.25
G90
G4 P.25
G4 P1.5
M15                              ;Unclamp Tool
N650
G4 P1
M95 /40
G90
M16                              ;Clamp Tool
GOTO 900
N800 ;Errors
GOTO 800
N900 ;Restore Modes
GOTO 1000
N950
M6
N1000                            ;End of Macro
Thanks, will take a look, much appreciated.
Chaz
Post by Chaz »
If I type M63 in MDI, then Output 3 on the Ether1616 should activate, correct? If it does nothing, what should I be looking at to fault find?
No, the default Acorn M63 turns on whatever output (if any) you have assigned the name "OUTPUT3" through the Acorn Wizard.
Greg
Post by Greg »
You can press alt-i to look at and toggle all your outputs for testing, no need for mdi commands.
