I have recently acquired the Plasma THC Controller for primary use as a plasma, but was considering the viability of making my table (currently under design) a combination router/plasma table. Is it possible for the Plasma THC Controller to support router operation?
Thanks in advance
Waz
Acorn Plasma THC Controller as router
- Plasma CNC Controller: Yes
- Plasma/Laser Lead
Re: Acorn Plasma THC Controller as router
Yes
When installing CNC12 you will see an option for a Router/ Plasma combination.
The installer will download both Router and Plasma versions with a Desktop swap button for jumping from the plasma to router software.
Perfect, thanks for your reply
Can I change from just a plasma THC Controller to a router/plasma at a later date if I require to use my plasma as a router
- Plasma/Laser Lead
Yes, You can switch at any time.
The only change between Plasma and Router is the software folder and license file.
