Rough Motion on Circular Toolpaths
spikee
Re: Rough Motion on Circular Toolpaths
Post by spikee »
for a servo loop, afaik it is easier to control it at high speed vs low speed. Hence why a certain gearing is recommended.
With bigger servos this is less of an issue due to it just having more torque.
Salted_Pork
CNC Control System Serial Number: 54453804251C-0118247882
Post by Salted_Pork »
Not sure if this changes anything, but I learned that these are not servos, they are “hybrid steppers/servos”, which is just a stepper with an encoder.
Salted_Pork
cnckeith wrote: Thu May 16, 2024 7:02 pm
no need to have smoothing ON with this type of g code. smoothing is for short vector g code. not G2's/g3's
see this for more info.
fyi..smoothing Will NOT make up for bad gearing or other mechanical issues.
Hi Keith,
So when I turn smoothing OFF aka exact stop, it runs really bad especailly as the feedrate increases.
see video:
When any smoothing setting is turned on, it runs /relatively/ smooth and at the correct feedrate.
For simple arc moves it seems this should not bog down the controller.
I attached a current report.
report_54453804251C-0118247882_2024-05-24_12-46-00.zip
(1.1 MiB) Downloaded 3 times
Salted_Pork wrote: Fri May 24, 2024 2:49 pm
Hi Keith,
see video:
post the g code program. the last one had very very short moves, so short that it was beyond necessary. adjust the minimum vector length in the cad/cam system so it doesn't put out .002" moves :D
Salted_Pork
[/quote]
[/quote]
Heres the relevant code for the circle:
(2D Contour9 (6))
N240 G0 X-4.0125 Y8.9505
N245 Z0.788
N250 Z0.388
N255 G1 Z0.258 F300.
N260 G18 G3 X-4.1125 Z0.158 I-0.1 K0. F200.
N265 G1 X-4.125
N270 G17 G2 Y12.2995 I0. J1.6745
N275 Y8.9505 I0. J-1.6745
N280 G1 X-4.1375
N285 G18 G3 X-4.2375 Z0.258 I0. K0.1
N290 G0 Z0.788
N295 G17
N300 M9
N315 M30
Not seeing any tiny .002" moves... Unless I don't understand how these arc moves work.
Your router is not running in the recommended turns/inch range and the motors are vibrating at low speed.
Smoothing is not the right medicine to cure this ;)
At least add gearing to bring it in the recommended sweet spot, this will also avoid the slow vibrating speed of the motors.
Salted_Pork
suntravel wrote: Fri May 24, 2024 5:15 pm Your router is not running in the recommended turns/inch range and the motors are vibrating at low speed.
Yeah just ordered some gear reducers, so working on that, hopefully fixes my problem (fingers crossed).
But regardless of gearing, i find it weird that i cant run simple programs without smoothing turned on, so i'm trying to figure that part out too.
A good smooth circle is not so simple, but this will be solved if the machine is running in the sweet spot if it is mechanical ok.
Salted_Pork
Salted_Pork wrote: Fri May 24, 2024 5:08 pm
Keith any ideas on this?
