Rotary axis with gantry router?
Is there a way to tease a 5th axis out of the Acorn in order to drive a rotary axis on a gantry machine that uses two motors for Y?
tnx.
g.
tnx.
g.
Re: Rotary axis with gantry router?
Five drivers, hardware pair two for Y (not software paired), then one for X and one for Z, and the rotary on the 5th (axis 4 in the wizard). Unless I'm misunderstanding.
Scott
Or, if you have to have software pairing, replace it with an Acorn6.
You can hardware pair the gantry axis to allow adding a 4th axis. Every ShopBot ever shipped from Durham has been wired in this manner. We are currently shipping our Acorn 4 ClearPath systems configured this way and are including independent axis Auto square
That's what I suspected. I was hoping to have auto-square, but I can't have both.
Thanks!
g.
Thanks!
g.
You CAN do auto square with hardware pairing. You use relays to cut the step/dir signals to the motors when you run just one motor at a time.
Ken
Yes you can. And by the time you are ready for it, hardware paired autosquaring may be baked into the wizard's cake!!!
Well I know with the Acorn I'm not going to get two independently driven X (or Y) motors, AND have a spare for the rotary.
g.
g.
Independently driven or have the ability to perform independent auto square? Your machine has never had an independently driven X motor, they are hardware paired.
I have been making auto square kits for ShopBot machines for about a decade, and have adapted that to acorn. Centroid is looking into making it a standard feature in a future release. Other users are doing it now with, as Keith says: "a roll your own" homing macro.
So, yes, for the 3rd time, you can have independent axis Auto square and a rotary 4th axis
Acorn Hardware Pair with Auto Squaring Gantry frees up 4th axis for Rotary axis.
Hookup schematic
https://www.centroidcnc.com/dealersuppo ... 200.r1.pdf
page 9
Hookup schematic
page 9
