Introduction video to using Notepad ++ and the NCnetic G code editing plugin.
and How to install it with the Centroid CNC PC Tuner.
https://centroidcncforum.com/viewtopic.php?f=61&t=10164
- CNC Control System Serial Number: 20915A (1124081904)
Re: Introduction video to using Notepad ++ and the NCnetic G code editing plugin.
ROGER THAT...
Works great...
Thank You...
BOB...
Works great...
Thank You...
BOB...
- CNC Control System Serial Number: F045DA7F1D5B-0109191641
Hi, There is a problem with the 1.30 PC Tuner installing the NCnetic plugin for Notepad++.
The PC Tuner only looks for a Notepad++ installation on the C: drive.
If Notepad++ is installed on a different drive, the PC Tuner is unable to located the installation.
Otherwise the NCnetic plugin is very nice.
thanks for reporting that. most will have it on the c: drive of course and you can install the plug in 'manually',TopQuarkDoc wrote: ↑Wed May 15, 2024 12:13 pm Hi, There is a problem with the 1.30 PC Tuner installing the NCnetic plugin for Notepad++.
Historically a long time user of Notepad++, and yep, did it manually. It works fine. The color coding for the different axes and parameters is nice. Like for other NPP uses.
- CNC Control System Serial Number: 0008DC111213-1005220061
Nice plugin! Do you know, if the backplot is also available for a lathe?
There is a pro version of the plugin for 4-5 axis machining, you can send an inquiry if he could make a multiaxis version for lathes.
https://ncnetic.com/notepad-gcode-plugin-pro
Can you install the plugin without having your machine setup to run cnc12 e.g. I want to run it on a computer not "tuned" to run a machine
It's a Notepad++ plugin. Other than being able to parse GCode it has no connection to actual machining.
If you can run Notepad++ then you can use the plugin.
