today i drafted a discussion paper on tool height offset methods
Re: today i drafted a discussion paper on tool height offset methods
Using external tool setting with Method 1 ( Z home Ref )
- CNC Control System Serial Number: 0035FF8D294B-0211225688
thank you uwe.suntravel wrote: ↑Tue Jan 23, 2024 2:06 pmI have less than 0.003mm deviation with a cheap NPN sensor, but I drive to the face of the sensor.
Mechanical is Balluff top notch, but expensive:
https://www.balluff.com/de-de/products/BNS004U
I don't understand what you mean by "I drive in front of the sensor?"
My optimum L28 CNC Lathe with ACORN
viewtopic.php?t=7831&hilit=aurelien
https://www.youtube.com/watch?v=Rqzrz87 ... reparation
E415F6F70BC3-0318203049
My understanding: Uwe is saying his Axis "flag" passes across the face of the sensor rather than approaching head-on.
Hope this helps
Nigel
Nigel
Mounting of the Z-axis NPN
yep for sure! thanks.cncsnw wrote: ↑Wed Jan 24, 2024 1:38 am You might also want to clarify that the prerequisites for using Z Home as Z Reference are both repeatable Z homing, and a fixed table height.
A knee mill with a closed-loop control -- which finds home using a switch combined with the encoder index pulse -- has entirely repeatable Z axis homing, but generally requires a physical reference tool because the tool measuring surface (the table) can move up and down.
excellent , will add.
A picture is worth more than 1000 words! Thanks uwe it's perfectly clear now.
rev3 attached.
I still need to incorporate all of your suggestions.
thanks.
- centroid tool height measurement_rev3.pdf
- (1 MiB) Downloaded 36 times
Will the new version auto store the tool offset in the library? I changed to z zero button to Z Reference so my brain understands.
If the homing wizard section had a spot to give an extra move it would help. So if the home limit switch for x is 2" from the home spot you want, you enter that number in the wiz. It would save having to make custom home macro's Nothing to do with the tool offset really but I wanted to remind you.
Ken
Ken
Ken
yeah. that is a good idea, i'm so used to just editing the .hom file, but that would be easy to add to the wizard homing menu. its on the list
