Issues During upgrade to Plasma pro
Moderators: cnckeith, Joey
Re: Issues During upgrade to Plasma pro
Glabs wrote: Thu Feb 08, 2024 12:18 pm We are using Nema 34 motors on x & y axis. We are using Fineline automations rack and pinion system( A high resolution 3:1 belt drive reduction )
Same answer, it doesn't matter what motor/gearbox/drive system or drive ratio you are using the MINIMUM steps/rev NEEDS to be 1600 or higher. This info is in the manuals and all over this site.
Have a look at this info posted by Centroid.
https://centroidcncforum.com/viewtopic. ... 936#p11936
Glabs
Plasma CNC Controller: Yes
Post by Glabs »
Joey asked for this information. That's why I posted it.
I tried to run a job today as a test.
When I start , i get an error on line 15 where a m83 is. not sure what its trying to do. I'm using my previous post processor through sheetcam. Any ideas? or a different post processor i should be using?
Joey
Post by Joey »
Download the Sheetcam Centroid Plasma Post here.
https://centroidcncforum.com/viewtopic. ... 483#p67483
Glabs
Post by Glabs »
Awesome Thank you. I will let you know how it goes.
CHAOTiC WAYz
Post by CHAOTiC WAYz »
ok, post processor is working through sheetcam. Now do i need a macro to fire the torch? Running the machine with the new post processor does a touch off using my float switch , and travels where it should, but never tries to fire the torch. When i was using the mill license , i had a macro to do the touch off, and a macro to check for arc ok then fire torch.
Joey
Post by Joey »
Do you have the "Torch on" assigned in the wizards output menu?
Do you have the Plasma's torch on ON/OFF Wires connected to that same input on the Acorn?
Glabs
Post by Glabs »
The output was the problem, I never set it when I switched to the plasma license. Thank you so much for your help. The machine works like it use to, now i can work on adding the thc . Thanks again.
