MPG Working in 1x Onlyn <resolved>
Re: MPG Working in 1x Only
You can make all Wizard inputs at once and then save them.
I just updated to R14 today on my machines.
avp
CNC Control System Serial Number: E062346A1C67-0716214939
Post by avp »
You can do all your entries then write once if you choose. I just do it in steps to check things.
Bill
RJS100 wrote: Fri Nov 10, 2023 11:08 pm Thanks Keith. Two quick questions:
1. When you hand enter the information into the wizard, do you have to hit Write To PLC for each page, or can you enter all the pages, then Write To PLC once?
2. I noticed that the tool library was blank after installing the beta version. I can't remember if this happened on my previous install. Is there a way to restore the tool library from the previous version?
Thanks again... Richard
yes the tool library is in the cncm directory. so after you get the new cnc12 install up and running simply copy over the old tool library to the new cncm directory and restart cnc12 and your old tool library will automagically appear in the new installation.
cncm.ol "offset library"
cncm.tl "tool library''
copy both of these files from the old cncm to the new one.
same with
cncm.wcs (this is the work coordinate positions data file)
and any of your custom macros .mac files if you have any etc.
RJS100
Post by RJS100 »
Thanks guys. As soon as the non-beta version is out (version 5.08). I will update as noted.
Thanks for all your help... Richard
Re: MPG Working in 1x Onlyn <resolved>
thanks for reporting back, we are very close on a v5.08 release candidate!
