Dynamic break wiring
Clausing2020
CNC Control System Serial Number: 3639
Post by Clausing2020 »
God Morning to everybody. Out of all you fine individuals there has to be some one that could answer this question. I have this Board that came out of the Original build of the machine. Mazak QT8. I have the wiring diagram. I have the 120 Volts hooked up and the motor wires. From what I am seeing I should be using TCW and TCCW to make the turret go Forward or Reverse. What I am doing is hooking a Output to TCW and TCCW It is not working the way I need If I jump the 5G / 03 terminal with 24 volts it will index if I try to jump the other SSR 5F / 03 It will short. I will leave at this and maybe somebody can look at this diagram and put me in the correct position.
Thanks John
img065.pdf
(1.06 MiB) Downloaded 72 times
