WMPG-4 pendant only works at 1x, but not 10x nor 100x
Re: WMPG-4 pendant only works at 1x, but not 10x nor 100x
TravisR100 wrote: Sun Oct 15, 2023 6:16 pm Was this issue ever solved? I'm having the same problem.
your probe input is tripped.
post a fresh report.zip so we can see your setup and error logs
TravisR100
Post by TravisR100 »
Report attached.
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Post by Nigelo »
TravisR100 wrote: Sat Oct 21, 2023 6:54 pm Report attached.
Where is the Report.zip as it's not showing?
Hope this helps
Nigel
TravisR100
Hmm... trying again.
report_54453803DACA-0508237178_2023-10-22_13-25-43.zip
(840.85 KiB) Downloaded 4 times
According to your report:
- ProbeTripped is assigned to INP7, and is inverted (implying a normally-closed probe that opens when tripped)
- ProteDetect is assigned to INP6, and is not inverted (implying that INP6 closes when the probe is plugged in)
Check the Alt-i diagnostic display. What colors are INP6 and INP7 when:
1) The probe is not plugged in?
2) The probe is plugged in and not tripped?
3) The probe is plugged in and tripped?
Are you able to use the WMPG on x10 or x100, if the probe is plugged in and not tripped?
If your answers are:
1) Probe not plugged in: INP6 = RED, INP7 = GREEN
2) Probe plugged in and not tripped: INP6 = GREEN, INP7 = RED
3) Probe plugged in and tripped: INP6 = GREEN, INP7 = GREEN
... then your setups and wiring are correct, and there is a bug in CNC12.
TravisR100
"According to your report:
- ProteDetect is assigned to INP6, and is not inverted (implying that INP6 closes when the probe is plugged in)"
Yes, this seems correct and the way it is wired. Went through the setup instructions and didn't change anything other than as instructed.
1. Probe not plugged in: INP6=RED and INP7 = GREEN with a white line above it
2. Probe plugged in and not tripped: INP6=GREEN and INP7 = RED with a white line above it
3. Probe plugged in and tripped: INP6 = GREEN, INP7 = GREEN with a white line above it
Yes, I can use x10 and x100 with no problem with the probe plugged in and not tripped. It's when the probe is unplugged that it doesn't work. Basically the same problem the original poster described.
In 5.07R8 this problem is solved.
TravisR100
Hmm. OK. Thanks. I'll have to see what version i have and figure out how to upgrade.
