We are working on Adding Rapid Override controls to the VCP
Re: We are working on Adding Rapid Override controls to the VCP
Know this will be a very cool feature. Can you sell it in kit form so we can mount the knobs in a monitor enclosure?
ShawnM wrote: Mon Sep 11, 2023 6:13 pm Know this will be a very cool feature. Can you sell it in kit form so we can mount the knobs in a monitor enclosure?
that's the plan.
two DIY products are coming down the pipe for knob and buttons controls that connect to CNC12 via USB.
one product is just the three knobs as the concept drawing above shows the other is those knobs AND four of the most common buttons used when operating a machine.
these buttons will be user definable as well. so if you need some other action besides, cycle cancel, tool check, feed hold or cycle start you can hyjack it and make it do what you want. (with a little programming, we'll try to make it easy on you:-))
note: the estop button in the image above connects in the regular estop manner, Everything else is via a single USB cable.
That will be the cat's meow, looking forward to it. I'll take the first one. :mrgreen: (I'm not super crazy about the USB only connection but I'll try it)
I love the pot idea instead of using the VCP for spindle and feedrate, much easier to fine tune speeds and feeds. I only have estop, cycle start and feed hold on my DIY button box. Never saw the need for cycle cancel or feed hold but hey, why not?
This is my typical remote mounted button box on the end of the gantry. They are backlit with LED lights but the machine is off now.
thanks, where did you get the cycle start and tool check buttons?
cnckeith wrote: Fri Sep 15, 2023 4:05 pm thanks, where did you get the cycle start and tool check buttons?
Both the buttons and the legend plates came from Factorymation.com
They are my go to source for panel components.
cnckeith wrote: Tue Sep 05, 2023 9:29 pm one button to toggle
This one looks great, nice feature for setting up new parts.
slodat
Post by slodat »
cnckeith wrote: Mon Sep 11, 2023 6:30 pm
that's the plan.
This looks GREAT! I've added physical switches to my machines. On my lathe it's the only thing I needed the 1616 expansion for. Nice work!!
Switches are from Automation Direct.
slodat wrote: Wed Sep 20, 2023 3:21 pm
that's the plan.
cool, looks nice, thanks for posting
Joey
Post by Joey »
Nice look 👍
My preferred solution would be to have one of the Macro buttons on the WMPG to switch from feed/rapid override.
This is how my production CNC machines are working.
