MPG Hardwire AcornSix Wiring
usajet
Post by usajet »
Is there a schematic for wiring a hand wheel MPG encoders? Any documents for mpg pendant?
Re: MPG Hardwire AcornSix Wiring
Hello.
Chuck will post a typical hard wired MPG(s) to AcornSix specific schematic here tomorrow.
are you doing dual handwheels on a lathe? or?
for the Wireless pendant the WMPG-4/6 is selectable in the AcornSix Wizard, easy peasy.
usajet
Post by usajet »
Yes dual Hand wheels for the lathe.
usajet wrote: Mon Jul 10, 2023 11:41 am Yes dual Hand wheels for the lathe.
with joy stick?
usajet
Post by usajet »
And a Joystick for jog. And axis selector.
Why do you need an axis selector, if you have dual handwheels (one handwheel per axis)?
usajet
Post by usajet »
True
usajet
Post by usajet »
Sorry I meant for step selector.
x1, x10, x100 selections are on the VCP
and you can add a rotary switch that would wire into AcornSix inputs to work in place of or in conjunction with the VCP.
This would require some minor custom PLC programming to look at the inputs being used (wired to the rotary switch) to the determine x1,x10,x100 selection
