I have a new PC. I downloaded and installed a copy of v5.02 on that new PC. It started, I attached the license file and created a report (attached). On the old PC, I was running v4.62 and I attached a report from that installation(about a year old). I had installed v5.02 on the old PC and restored the v4.62 report. I KNOW NOW that was not the correct thing to do but after a few tweaks in the wizard it was working. I created and attached a copy of a report from that installation. During all of these changes between versions I was doing all the appropriate c:/cmd file renaming etc.
I went back to the working v4.64 setup. I then created screen shoots of the wizard screens (what a pain in the a**!) attached. The problem is I was NOT able to get screenshots of any of the screens in the Primary system (see attached png.) When I went to the new 5.02 install on the new PC I had no idea what to put in those settings. I have a lot of input mods. I did those in 2019. I don't remember them.
So how do I get that info back?
extremely frustrated after v5.02 install
Re: extremely frustrated after v5.02 install
I'm not sure this post had the attachments I referenced so here they are.
- report_F045DA79A18B-1205181402_2022-01-21_16-09-05.zip
- (692.72 KiB) Downloaded 1 time
- Screenshot 2023-06-30 122546.zip
- (3.09 MiB) Downloaded 1 time
- Screenshot 2023-06-30 161043.png (17.23 KiB) Viewed 1266 times
- report_F045DA79A18B-1205181402_2023-06-30_12-12-26.zip
- (707.01 KiB) Downloaded 1 time
- report_F045DA79A18B-1205181402_2023-06-30_11-49-47.zip
- (889.21 KiB) Downloaded 1 time
- CNC Control System Serial Number: A81087B4FFCB-0712192265
That is because you have the "Custom PLC" option set to YES in Wizard (Preferences -> Wizard). Set it to NO and your "Primary System" info will be available. If you indeed have a custom PLC, set the "Custom PLC" toggle switch back to YES, after you take screen shots of the data from "Primary System".eswakon@eas-eng.com wrote: ↑Fri Jun 30, 2023 7:20 pm ... The problem is I was NOT able to get screenshots of any of the screens in the Primary system (see attached png.) ...
Thank you. Indicating I did NOT have a custom PLC allowed me to capture those screens.
