Acorn Six enable output on H13 and H14...
1. Is it only 5V or capable of 24V as well
2. Is it sinking or sourcing?
AcornSix Enable
Re: AcornSix Enable
Update...
Page 40 of the AcornSix Install Manual rev12 shows +5v to the enable + and the enable - going to the H13 and H14 connectors.
but diagram for a Leadshine CS-D1008 show the enable out from the Acorn going to the enb+ on the drive and enable - on the drive going to grnd.
Re: AcornSix Enable
page 40 also says. "An example of drive wiring is below. Please consult your schematic for drive specific wiring."
so use.
https://www.centroidcnc.com/dealersuppo ... 147.r2.pdf
so use.
Re: AcornSix Enable
Not sure how the output can be sourcing and sinking, but OK, I'll wire like that and see what happens.
Re: AcornSix Enable
See page 81 of the AcornSix install manual for a description of the outputs.
Headers H13 and H14 are 5V logic outputs (High = +5VDC , Low= 0V/GND).
Headers H1, H2, and H3 are open collector outputs (sinking).
Re: AcornSix Enable
Thanks, completely missed that.
