New Centroid Teknic Clearpath officially supported configurations. Updated 5-10-23
jasonstewart81
Re: New Centroid Teknic Clearpath officially supported configurations. Updated 5-10-23
Post by jasonstewart81 »
So I'm still trying to fully understand the auto squaring. I have clearpath SK motors on each Y axis and I'm using the cnc4pc c86accp with Y slaved. Can I do the hard stop homing with this configuration as I'd eventually like to utilize my A (4th) axis for a rotary in the future.
jasonstewart81 wrote: Wed May 17, 2023 6:52 pm So I'm still trying to fully understand the auto squaring. I have clearpath SK motors on each Y axis and I'm using the cnc4pc c86accp with Y slaved. Can I do the hard stop homing with this configuration as I'd eventually like to utilize my A (4th) axis for a rotary in the future.
its a homing selection in the v5.0. Wizard. clearpath setup link to instructions is on same page.
set up c86 for hardware pair.
clearpath setup link to instructions here as well
https://www.centroidcnc.com/dealersuppo ... ds/319.pdf
jasonstewart81
cnckeith wrote: Thu May 18, 2023 5:21 pm
Thank you Keith. Yeah I was looking at that documentation and just wanted to confirm I was understanding it correctly. I guess if set up correctly it is a pretty accurate repeatable way of homing. Would be nice to implement auto squaring and eliminate the need for homing sensors (switches) if I can. The cnc router I have (onefinity) originally came with stall homing and standard stepper motors, but that process wasn't very accurate.
yep! that's why we did it, documented it and added the feature to the Wizard, works great, no wires/switches to install or go bad and frees up 4th axis for rotary work and you still have autosquaring. you can have your cake and eat it too.
make a build thread and post info and photos of your project for others to see please. we need to get the word out.
Gary Campbell
Post by Gary Campbell »
Arturo at CNC4PC has updated the jumper setting and connection manual for the C86ACCP board on his website:
https://cnc4pc.com/forum/projects/instr ... reply-1059
CNC Depot Modular ATC kits
johannes
Post by johannes »
I have used this for my second router now. Works very well, and super easy. Not a single limit switch on my machines, and super reliable.
I have adjustable hard stops on Y, so I can fine tune the squareness of the gantry (remember to clear the memory of precision hard stop homing in the Clearpath software each time you adjust). You then get super repeatable, square gantry each time.
johannes wrote: Sun Jul 21, 2024 2:47 pm
cool, please post some photos/video i'm sure others would love to see what/how you did it. :D
johannes
Post by johannes »
cnckeith wrote: Mon Jul 22, 2024 7:51 pm
I finally put together a post here:
viewtopic.php?f=57&t=10530&p=90880#p90880
Let me know if I should describe it in more detail.
grossmsj
Post by grossmsj »
johannes wrote: Sun Jul 21, 2024 2:47 pm (remember to clear the memory of precision hard stop homing in the Clearpath software each time you adjust). You then get super repeatable, square gantry each time.
Agreed it is really accurate and dependable. The only glitch I've run into is an occasional (once a month?) situation where my Y-slave motor will back off too far during homing. It's easily observable and I can even hear how different the motor sounds. Clearing the precision homing selection corrects the problem. After having this happen a few times, I just turned off the precision homing option for both Y motors. I haven't seen any loss of accuracy nor have I had the problem occur again.
-Scott
grossmsj wrote: Mon Aug 26, 2024 7:20 pm
great info , thanks for posting. i did observe the same thing at least a few times!
