SOLD-05/22/2023 Southbend Magnaturn 612 with Acorn
- CNC Control System Serial Number: 6200 on the All In One and 1814 on the Acorn
Started this project a few years ago and then had a hand injury that required surgery. It complete and running except for the turret. The turret can be manually changed from tool to tool right now and that's how I used it for a couple of parts. I do have a new servo, motor controller, and power supply that was to be used to power the turret so everything is here with it. The servos were new DMM. Will sell for $2500. Lathe runs off 30 amp 110 standard outlet. Has Coolant tank and pump that runs from the control. Computer is HP all in one and Centroid is the Pro Version. Has encoder on the spindle and will rigid tap. PM me for more info. I can send more photo's or even facetime a serious buyer. I have a forklift so loading isn't a problem. Located in south west PA.
Re: For Sale Southbend Magnaturn 612 with Acorn
nice little lathe, i had one of those a long time ago!
- CNC Control System Serial Number: 929110276
Where are you located? I've been trying to send a pm to you but 4 messages just sit in my outbox without being sent.
John
John
