lathe C axis code sample? Centroid < answered >
frijoli
Post by frijoli »
Are there any samples of C axis code fore Centroid controls. I am finding lots of examples that don't work, but none from actual Centroid machines. Centroid doesn't accept G17-G19 so I am confused on how Centroid intends it to be done.
There is nothing in the manual showing programming of wrapped tool paths nor face tool paths.
I did manage to write a post processor, in which I generated a program through Fusion 360 and generated a tool path that I believe will work.
Unfortunately it runs REALLY slow when using the c axis. I know why it's slow, but I don't know how to correct it.
So can anyone point me to some code?
Clay
Clay
near Winston-Salem, NC
Re: lathe C axis code sample? Centroid
clay, the reason its slow is the feedrate on the c axis program line is that the F command is in degrees per minute for a rotary axis.
so for example...
G1 Z2C3600 F2 that means the C axis is going to go 10 revolutions at 2 degrees per minute while the Z axis is interpolated to move to 2.0000 from the position it is at to 2.0000 in the time it takes for the C axis to rotate 10 times at 2 degrees per minute. (very slow)
Gary Campbell
Post by Gary Campbell »
Clay...
I have no idea how you get it into a Fusion postP, nor the syntax for math function in the Centroid controller, but what I have used in the past to get a realistic feedrate (matching XY) for a rotary axis is:
115 * ({desired surface feedrate} / {diameter})
CNC Depot Modular ATC kits
frijoli
Post by frijoli »
Gary Campbell wrote: Thu Jan 04, 2018 1:01 am Clay...
Thanks Gary. What does the 115 represent? Also, how does that work when switching from rotary to straight lines? I assume you are programming this line by line as opposed to canned cycles?
Clay
Clay
Gary Campbell
Clay...
Round numbers for 114.59 or 360 / pi
cnc_smith
Post by cnc_smith »
Clay,
I have attached a sample g-code program for C-axis for the Centroid lathe. This has the feed in degrees per minute. When X or Z are moving without a C-axis move on the same line of G code the feed rate (F) is in inches per minute. This program uses the M51 and M50 to turn C-axis on and off and the M23 and M25 to turn the live tooling on and off. ( If you are using different M codes for these functions you will have to change this program to those M codes to graph and run this program). This is the same part that is shown on the Centroid website. http://www.centroidcnc.com/cnc_c_axis_lathe.html
there are photos of the part and go down to the bottom and there is a video of the part being machined.
To use a third party post processor you'll need to set the CNC Controller type for the feed to Feed in degrees/minute.
C_AXIS_EXAMPLE_1.txt
I changed the file extension from .cnc to .txt to attach the file. Centroid will run this program with the .txt extension.
(16.27 KiB) Downloaded 161 times
Dana
frijoli
Post by frijoli »
cnc_smith wrote: Thu Jan 04, 2018 11:07 am Clay,
Outstanding, Thank you!!
Clay :D
Clay
