no, Hopefully Les will add it in the SheetCam post for you to test.
Thc non plasma usage
Re: Thc non plasma usage
Hey, so I've spoken with les and he tried ang trying his best to help me, he made me a plasma rotary post processor but but I'm unable to properly use it because the pierce cycle according to les, I'm posting the post he made down bellow hopefully joey will be able to help .
The post processor is also switching between the x and the y.
Alrigth Tamar! Thankyou you Les! He may take a little to answer but he always comes through! ill see what i can do.
I gave les your email address, he wanted to contact you for help with the post processor.
Yes I'm in contact with him now. He needed a way to wanted a way to set Pierce height in the gcode.
I've replied with this information. thought id post it if others are interested.
To separately control the pierce height from the profile. add the following in the G&M Code,
DEFINE <PIERCE_HEIGHT> 0.2 ;Sets Pierce Height to 0.2
0.2 is an example, >0.2 can be changed to the desired pierce height
This will need to be done after the M65, but sometime before the first M61. It will apply to all M61's in job as long as M65 is not called again.
This is the post processor that les from sheetcam made for me.
The rotary axis is B.
and the post is also switching between the X axis and the Y axis.
This post is working with the THC.
Here are more videos of the rotary cutting with normal speed and the post compressed file.
I've made today a new prototype rotary attachment cause the previous one wasn't accurate enough.
In about a month I will receive all the fiber laser equipment and then the games will really begin
Hey, how can I set the rotary axis home position in cnc12? Without homing switch.
Laser Thc working with the sheetcam rotary post .
M26 /B or whatever your rotary axis designator is. You can add this to your .hom file and it will set the rotary home to it's current position.
