Hey, just giving you an update that I've managed to make it work as it should! Thanks alot for your help! Much appreciated.
Now after all the test I've ordered today all the necessary fiber laser equipment .
Probably will take about a month and a half to arrive so I will keep you updated when I will set everything.
On another topic I have a rotary attachment (A axis) on my machine that I plan to use with the future laser as well, so I just purchased sheetcam rotary plasma plug in.
I'm new to sheetcam.
I can't managed to make the rotary work for same reason, I think that the problem its the post processor.
Also in sheetcam the A axis is along the X axis and I need it to be along the Y axis.
Does anyone have experience in this?
I've looked in the dissertation on sheetcam rotary plasma but didn't get the answers that I needed.
Thc non plasma usage
Re: Thc non plasma usage
OK got it.
But I'm still having problems with the rotary axis.
I have a rotary attachment B axis in wizard.
And I imported a program i made this sheetcam but the rotary axis doesn't move..
Can you send me a post for sheetcam that can support rotary plasma?
I don't use sheetcsm so I can't help you there. Can you rotate the axis using MDI to verify it's configured and connected correctly?
Yes I can rotate it using the remote control.
Its configured correctly.
post the offending g code program
this is the gcode
;Filename: 1010.tap
;Post processor: centroid_plasma_thc_sheetcam.scpost
;Date: 11/04/2023
G21 ;Units: Metric
G90
M65
;Part: 6060 x
;Operation: Outside Offset, 0, T1: 6 mm Steel quality 45A 127V
G0 X110.0763 Y22.639
M61
G2 Y19.9237 I-1.3576 J-1.3576 F[<FEEDRATE>]
G2 I-10.0763 J10.0763
G2 X107.361 I-1.3576 J1.3576
M62
G0 X182.67 Y58.08
M61
G2 X180.75 Y60 I0 J1.92
G1 Y89.25
G1 X239.25
G1 Y30.75
G1 X180.75
G1 Y60
G2 X182.67 Y61.92 I1.92 J0
M62
G0 X211.92 Y152.67
M61
G2 X210 Y150.75 I-1.92 J0
G1 X180.75
G1 Y209.25
G1 X239.25
G1 Y150.75
G1 X210
G2 X208.08 Y152.67 I0 J1.92
M62
G0 X92.639 Y139.9237
M61
G2 X89.9237 I-1.3576 J1.3576
G2 I10.0763 J10.0763
G2 Y142.639 I1.3576 J1.3576
M62
G0 X-3.2456 Y239.4697
M61
G2 X-0.5303 I1.3576 J-1.3576
G1 X59.25 Y179.6893
G1 Y120.3107
G1 X-0.5303 Y60.5303
G3 X-0.75 Y60 I0.5303 J-0.5303
G1 Y0
G3 X0 Y-0.75 I0.75 J0
G1 X350
G3 X350.75 Y0 I0 J0.75
G1 Y60
G3 X350.5303 Y60.5303 I-0.75 J0
G1 X290.75 Y120.3107
G1 Y179.6893
G1 X350.5303 Y239.4697
G3 X350 Y240.75 I-0.5303 J0.5303
G1 X0
G2 X-1.92 Y242.67 I0 J1.92
M62
G0 X0 Y0
;Filename: 1010.tap
;Date: 11/04/2023
G21 ;Units: Metric
G90
M65
;Part: 6060 x
M61
M62
G0 X182.67 Y58.08
M61
G1 Y89.25
G1 X239.25
G1 Y30.75
G1 X180.75
G1 Y60
M62
G0 X211.92 Y152.67
M61
G1 X180.75
G1 Y209.25
G1 X239.25
G1 Y150.75
G1 X210
M62
M61
M62
M61
G1 X59.25 Y179.6893
G1 Y120.3107
G1 Y0
G1 X350
G1 Y60
G1 Y179.6893
G1 X0
M62
G0 X0 Y0
I'm trying to cut square and round tube using an attachment
rotary axis on my cnc plasma cutter.
The rotary axis move correctly using to remote hand-held controller, but when I'm generating a gcode using sheetcam and sheetcam post there is no mention of the rotary axis in it.
And when I do simulation on sheetcam I can see the movement of the rotary axis.
So I'm guessing that the problem is the post processor.
Please help me with this matter
have you contacted sheetcam?
Yes, no answer from them yet.
The post that I'm using can support a rotary axis?
