Grizzly G0752 10 x 22 Metal Lathe with Centroid Acorn CNC conversion for sale. Lathe frame was purchased in 2015 and Acorn CNC conversion was added 5 years ago. Machine has experienced light occasional use boring pulleys and gears along with machining ends of ballscrews for custom machines, which we no longer sell.
The lathe is mounted on a 54” HD roller cabinet with 11 drawers and 1800# capacity. Centroid Acorn4 Pro lathe controller, ASUS 15” touchscreen, Lenovo M92 CNC-PC and Centroid Wireless MPG controller.
14 numbered tool holders for cutting, threading, knurling and boring bars. Dozens of HSS, brazed carbide and carbide insert tools with spare inserts for most. Multiple drill chucks and live centers. A decent supply of precision machinable drill rod shafts. Dial indicators with both mechanical and hydraulic magnetic bases.
Also included is a toolpost grinder and an Omron encoder, both new in box should the purchaser care to implement them. Lathe CNC motion is provided by 900 and 500 ozin Leadshine steppers driving 5mm and 4mm pitch ballscrews. Can be upgraded to Teknic ClearPath servos for an additional $1250.
Full lathe specs here: https://www.grizzly.com/products/grizzl ... kkQAvD_BwE
Video of machine:
Video showing Clearpath servos on another machine: (in progress)
Pickup is preferred, but unit can be crated and shipped LTL freight at purchasers expense. Price: $5,000 email: gcnc411@gmail.com for more information. Full pics in attached PDF
Grizzly G0752 Metal Lathe with Acorn Conversion (SOLD)
- Grizzly G0752 CNC Lathe conversion.pdf
- (816.6 KiB) Downloaded 31 times
Last edited by Gary Campbell on Fri Apr 14, 2023 11:47 am, edited 1 time in total.
Re: Grizzly G0752 Metal Lathe with Acorn Conversion (SOLD)
SOLD
Thank you all for your inquiries
