Is it possible to use the encoder port on the Arcon and use a corded MPG? Or is the only option the wireless Centroid MPG?
Thanks!
Corded MPG on an Acorn?
Re: Corded MPG on an Acorn?
sure..its the axis selector switch that hogs up a bunch of inputs..so yes you can do it, is it practical? not really.
AcornSix has three encoder ports so you can dedicate a hard wired MPG per axis on a lathe.
Thanks for the response! Hmmm okay, that makes sense. I haven't counted all the inputs required but I don't have many inputs used so I figured it wouldn't be an issue.
Thanks again!
On a slight tangent (not wanting to hijack this thread; sorry! ), is it possible to control all 6 axes using a Centroid wireless pendant? I'm considering using the A6 board for a Swiss lathe build.
You have to wait for the WMPG-6 for this.
Nope, but software is ready, you can choose this in current 4.99 beta.
We have wmpg-6 now! Just need to get it on the website. Ask diysales@centroidcnc.com and they will hook you up.
Thanks Keith! I've just had an email from Nancy with a link, and will be placing an order soon!cnckeith wrote: ↑Mon Mar 20, 2023 1:08 pm We have wmpg-6 now! Just need to get it on the website. Ask diysales@centroidcnc.com and they will hook you up.
Question; which version of CNC12 should I use to run a 6-axis lathe?! (X, Y, Z, and Rotary for the main spindle, and a second Rotary and Z for a sub-spindle.)
