CNC on the cheap. Kai's Techno Router Acorn CNC controller build part list
Kai's Techno Router Acorn CNC controller build part list. CNC on the cheap.
Leadshine Closed loop stepper motors and drives.
2x CS-M22323-S
1x CS-M22323B
3x CS-D508
3x 3 meter long cables
Brake motor on Z
Motor drive power supply
USB communication cable for communicating with drive
Amazon links to parts used in this build.
updated links with Stepper Online axis motors and drives! 3-20-25
Closed Loop axis motors and drives.
https://amzn.to/4kFtz7B
power supply.
https://amzn.to/4ijG735
Electrical Box
https://amzn.to/3IvBT8P
CNC PC
https://amzn.to/3IuvSZZ
Touch Screen
https://amzn.to/3kl1GY6
Din rail terminal blocks
https://amzn.to/3YZIBtl
Din rail.
https://amzn.to/3xuijU5
Wire Markers
https://amzn.to/3k02zp0
Quick Docking wire connectors
https://amzn.to/3XHZdV7
Din rail terminal block quick connect.
https://amzn.to/3xtgBm1
Dial indicator with mag base.
https://amzn.to/3I6TsLc
Lever nuts connectors.
https://amzn.to/3Ecl00g
more lever nut connectors.
https://amzn.to/3XHL62e
120mm x 25 mm cooling fan
https://amzn.to/3XCiBmw
Electrical box main power rotary switch
https://amzn.to/3S56eyc
6A circuit breakers.
https://amzn.to/3YDAtyC
Push button estop.
https://amzn.to/3I72DLt
DB25 flying lead for easy drive connections.
https://amzn.to/3IaGEDm
Shielded signal cables 22 gauge. two conductor with ground
https://amzn.to/3xpNIY1
Din rail 24 vdc power supply 1 amp
https://amzn.to/3EauXeM
Din rail 24 vdc power supply 3 amp
https://amzn.to/3k1KDKB
Stepper motor to ballscrew coupler
https://amzn.to/3Eghimt
Physical Cycle Start, Feed Hold, Tool Check and estop
https://amzn.to/3YEojWv
Wire track for Z axis cables on gantry.
https://amzn.to/3lJabN7
Fan dust filters
https://amzn.to/3xthUkV
3 foot shielded ethernet cable.
https://amzn.to/3YJllQE
Wire.
https://amzn.to/4103DtB
Wire stripper.
https://amzn.to/3S3PPKy
Small wire stripper. for those tiny db25 wires!
https://amzn.to/3Kb8mmf
alternative.
https://amzn.to/3Id8Cyt
Basic wire stripper
https://amzn.to/3IfrWLt
More gear we use but don't sell is here.
2x CS-M22323-S
1x CS-M22323B
3x CS-D508
Brake motor on Z
power supply.
Electrical Box
CNC PC
Touch Screen
Din rail.
Wire Markers
Push button estop.
Fan dust filters
Wire.
Wire stripper.
alternative.
Basic wire stripper
1 user liked this post
- CNC Control System Serial Number: 6679
Re: CNC on the cheap. Kai's Techno Router Acorn CNC controller build part list
Nice! I wish I found that enclosure before buying a Hubbell. Mine is smaller and a lot more expensive. Would be interested to know how he has the relay board suspended above the Acorn?
he made a plexi cover for Acorn and put through holes in it to mount the relay 8 board.
you can see it better in this photo.
Kai Techno Router to Acorn photo album
i'll be adding more photos and videos over the coming weeks.
Cheaper quality strippers by Klein: https://www.amazon.com/Stripper-Strande ... B000XEUPMQ
Brady Watson | IBILD Solutions | Production Consultant | HiDef 3D Laser Scanning | Vectric Custom Video Training | IBILD.com
Nice! Thanks for sharing the album.
good ones! i added to the list.BDubs wrote: ↑Fri Feb 17, 2023 10:49 pm Cheaper quality strippers by Klein: https://www.amazon.com/Stripper-Strande ... B000XEUPMQ
I updated the Gear we use but don't sell page with new items and updated links.
amazon broke all affiliate links that had images world wide! so, i redid the page with static links and added a few and fixed a few others.
