8 Relay Ver. 1.1 hookups
ShaAli
Post by ShaAli »
Hello,
Would it possible to help me figure out how do I connect (wire) some 110v devices like shopvac, air compressor using this relay? I tried to search for the wiring diagram and I was not able to find. I am it exists :)
Thank you so much for all your help.
Gary Campbell
Re: 8 Relay Ver. 1.1 hookups
Post by Gary Campbell »
Those devices draw too much current to be connected directly to the acorn relay board and should be controlled by a contactor
CNC Depot Modular ATC kits
And that contactor Gary mentioned is then controlled by one of the 8 Acorn relays.
TheKitMill
Post by TheKitMill »
Something like this will control the things you want to turn on and off like shop vac etc
Gary Campbell
If you do use an SSR, make sure that you use one designed to match your load type. AC Inductive, resistive and capacitive loads are each best served by slightly different specs. And use 2 (or a double pole) if switching 230VAC. Also, since many DIY guys buy on price, after wiring is complete, make sure that the load terminals go to zero volts when off, not all of them will.
ShaAli
Post by ShaAli »
Thank you all for your valuable information. I appreciate it very much
