Hardinge chnc turret
- CNC Control System Serial Number: noneT39 2153
How do you wire and setup turret using acorn. It is a new install
Re: Hardinge chnc turret
the chnc turret is a sweet turret!
not sure if anyone has done it yet with Acorn, but we did a bunch of them with allin1dc.
the turret documentation we did 20 years ago is here.
https://www.centroidcnc.com/downloads/c ... Manual.pdf
pick up a Ether1616 to go with the Acorn to add the additional i/o you are going to need with the chnc.
How do I designate the inputs and outputs
How do I designate the inputs and outputs and what parameters need to be changed
download the Acorn atc zip file and look over the instructions.
located in the "All Acorn Documentation" page. here.
https://centroidcncforum.com/viewtopic.php?f=60&t=3397
look for.
Acorn CNC12 v4.80 ATC programs and instructions
look for.
It tells you to use inputs 1 thru 4 on acorn but they are 24 v this is 12 v so I used inputs on ether 1616 and installed resistors for 12 v Is this the correct way to go
