Hello,
It may be a silly question,
In F360 there is a chamfer tool path, for CNC12 do I use the Frame cycle as chamfering (first calling the tool) ?
Is there anything else I need to adjust (like cuttercomp) to have 45 deg chamfer on lets say my 1 inch circular part
Thank you for your help.
Chamfer via Intercon
Re: Chamfer via Intercon
Pocket and frame routines can be used for chamfering. You will need to adjust the tool diameter and depth.
Thank you
