Centroid CNC12 v4.99 rev3 BETA for AcornSix is now available
Re: Centroid CNC12 v4.99 rev3 BETA: CNC code display after run
cncsnw wrote: Thu Jan 12, 2023 2:17 pm One quick reaction after running v4.99r3 for the first time:
I definitely dislike the way that, as soon as you cancel a running job, it reverts to displaying the first 11 lines of the program, with line 6 boxed as if it were the current/active/last line of code that was running.
The longstanding behavior, that after a program ends or is canceled, the line that it was last running is boxed in the center of the display, was useful and intuitive.
If the intent of the new design is to show that -- because the job was canceled -- it has been reset to the beginning, then the box should be around line 1, not line 6.
i agree. will tweak that.
in mean time, in the wizard, under CNC control preferences you can select "NO" to Part Program Preview on Job Load.
Re: Centroid CNC12 v4.99 rev3 BETA for Acorn, AcornSix is now available
and...hopefully will have rev4 out by end of week.
fixed up the g code preview
what it looks like after loading a job.
I want to add a scroll bar to this one at some point so users can scroll thru and take a look at it without having to open the editor.
while running, shows you line that it is executing
after cycle cancel retains the line that cycle cancel/estop etc. was encountered on.
Nice, thank you.
These are great additions to CNC12, thank you.
Sword
Post by Sword »
Need a two thumbs up emoji! 8-)
Scott
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Post by Nigelo »
+1 as above. This just gets better and better Keith - Hats off
Hope this helps
Nigel
Gary Campbell
Post by Gary Campbell »
Nice job!! Thanks to you and the guys for all the hard work.
Muzzer
Post by Muzzer »
Indeed, very much appreciated - this is something I wished had been there previously but never thought of requesting! A scroll bar would be the icing on the cake.
Re: Centroid CNC12 v4.99 rev3 BETA for AcornSix is now available
After some time testing v4.99 beta rev3 we have found.
- Plasma is broken. so don't use v4.99 rev3 with plasma
- Acorn Axis pairing is broken so don't use v4.99 rev3 with a machine that has software paired axes. (AcornSix is working)
axis pairing in Acorn has been fixed, still working on fixes for plasma and then we will release a v4.99 rev4
Locked
