Limit Switch Struggles Shopbot PRS
I am attempting to get my limit switches working for simple safety tripping.
I have X and Y limit switches.
They are wired in series between common and Input 2 on the Acorn board.
Acorn configuration shown in below image.
If I set input 2 to NC I can move the machine, but limit switches do not trip.
If I set input 2 to NO machine says X/Y/Z is tripped and I can't move the machine.
I am not really sure what to do, I have watched Marty's video on this topic and not sure I am on track.
Also if a limit switch trips, how do I move the machine off the tripped switch? I tried reset, but no joy.
Re: Limit Switch Struggles Shopbot PRS
Kurt,
Are these mechanical switches or the SB 3 wire inductive? Assuming mechanical and with 3 tabs (com and NC or NO), are you sure that you have them wired in series properly? Check them for continuity when not tripped (closed). You can also use the I/O diagnostic screen to check the state of them (Ctrl+I), and to see if you possibly have INP2 forced on.
To get off a tripped limit, use "Limit Switch Defeat" for a one shot move to get off them.
Scott
I have tried limit switch defeat and no joy.Sword wrote: ↑Sun Dec 04, 2022 1:30 pm Kurt,
They are not mechanical, they are from automation direct I had them on my SB before Acorn and they were working as expected.
"Micro Detectors inductive proximity sensor, tubular, 8mm diameter x 29.4mm body, stainless steel housing, NPN, N.C. output, 2mm sensing distance, flush, 7 kHz switching frequency, IP67, 3-pin M8 quick-disconnect."
Below is wiring diagram provided by manufacturer.
Kurt...
Maybe not the instructions on how to fix what you are experiencing, but advice in a different direction. This will allow you to make your machine perform better than it ever could on the SB3 control software.
Use the sensors to home the machine, ON ALL 3 AXES, and use the built-in travel limits to keep the machine off the hard stops. There is no guarantee that prox sensors will work in series, you must connect and test one, then two, then 3 to ensure they will work properly.
Since I always use discreet pins for limit/homing sensors I am not sure that the SB positive end target bolts will work with the Acorn controller, especially in the multi axis, multi direction setup.
Some questions:
Can you trigger each of the sensors with a wrench and see the sensors indicator light change state? If yes, does the assigned input light on the Acorn board change state also? If no you have something wired wrong.
I still recommend adding a sensor to the Z and set up homing and travel limits on all 3 axes like the big boys do, not the "do it cheap and simple" way that SB does.
Some questions:
CNC Depot Modular ATC kits
When you had them working on the ShopBot, did you have them all wired together in series to a single input? Or did you have each sensor on a separate input?
How many sensors do you have connected together in series?
Can you sketch your wiring for how you have connected them together in series?
- CNC Control System Serial Number: F045DA78F172-1129181385
I agree with Gary.
Use them to home your machine.
And set your travel limits in the software.
That’s how my PRT is setup, works a treat.
Agreed as well, sensors on all three, each to their own input, and use software travel limits. Been working great on my PRS for 4 years.
Scott
Thanks Gary, and for everyone's information, I wired them in series because that is what my Acorn Wiring Diagram had on it. I am a newbie here and did not realize that I could wire them into different inputs.Gary Campbell wrote: ↑Sun Dec 04, 2022 2:24 pm Kurt...
For Gary Cambell, I did order a Z Axis probe as you suggested and will get that in place now rather than later.
For cnckeith, thanks so much for that diagram, with that and Gary's suggestions, I should be on track to make progress.
This has been a long journey for me trying to get my Acorn Upgrade done, but this forum has been a life saver for me.
Regards,
Kurt
