Acorn CNC12 v4.80 has been released. (8-12-22)
Re: Acorn CNC12 v4.80 has been released. (8-12-22)
This is the final version.
BillB
Post by BillB »
ShawnM wrote: Sun Sep 25, 2022 9:40 pm This is the final version.
Cool thanks.
CNCMaryland
CNC Control System Serial Number: F045DA7CBF8b-103011290
Post by CNCMaryland »
Any known bugs at this point? I keep running into what I believe to be a bug in the software.
I don´t think there are bugs on lathe and mill, both worked without issues on my machines.
CNCMaryland
I need to see if I can re-create the error. It results in the software abruptly closing while measuring a tool height. It happened 2x. The report doesn't capture anything however.
CNCMaryland wrote: Wed Oct 19, 2022 10:27 am I need to see if I can re-create the error. It results in the software abruptly closing while measuring a tool height. It happened 2x. The report doesn't capture anything however.
Post details about the cncpc
And freshreport.zip.
CNCMaryland
Operating System info:
Edition : Windows 10 Enterprise (10.0)
Version : 2009
OS Build : 19044.2130
Memory info:
Total physical memory : 17064079360
Available physical memory : 13923356672
Processor info:
Intel(R) Core(TM) i7-4785T CPU @ 2.20GHz
Number of cores : 4
Number of logical processors : 8
Single Thread Score of 1750
report_F045DA7CBF8B-1030181290_2022-10-17_23-07-21.zip
(800.93 KiB) Downloaded 16 times
run the communications stress test in the v4.80 /ncfiles directory.
CNCMaryland
cnckeith wrote: Thu Oct 20, 2022 8:09 pm run the communications stress test in the v4.80 /ncfiles directory.
I have multiple times and it passes each time without exception.
more info on the tool touch off setup please.
