M400S Will not Boot Up
- CNC Control System Serial Number: 20541
Help, I have a M400S, Serial Number 20541 that was upgrade a few years back to the newer operating system. No more compact flash card, now has an 250G SSD that I purchased from Centroid CNC. For some reason the system will not boot up, it hangs on a screen that says "Booting Desktop ---2.6.31.5-0.1". Then it just sits there and never boots up. Any ideas, do I need to send my SSD back to be a reformat? I need to get this grizzly mill back up and running.
Re: M400S Will not Boot Up
double check both ends of the ssd cable. properly disconnect (with power off) and reseat connectors and try again.
Yes, it is worth checking connections. I suspect a corrupted SSHD though.
The "Booting Desktop..." message is part of the Suse Linux boot process, which comes from the SSHD. Normally, the next messages would be "root (hd0,0)" and "Filesystem type is ...". See ca. 0:05 in this video:
A hardware issue on the motherboard is also a possibility. Testing with a known-good SSHD would answer that question.
Thanks, I will check that, and let you know if it works. I'm suspecting the SSD as well, but was under the impression that SSDs don't just crash like hard drives used to do.
