Attached in this Post is the Post Processor for Sheetcam and Fusion 360.
I've also created a short video on how to set up path rules for commanded slower feed rates in Sheetcam.https://photos.app.goo.gl/iv6HXpC7AJc6BmCj8
New is the Sheetcam Rotary Post Processor. Any issues with this post please report back your findings
Post Processor Sheet Cam/Fusion 360
- PlasmaRotary Centroid V6.zip
- Sheetcam Post for Acorn Plasma Rotary
- (2.41 KiB) Downloaded 11 times
- centroid_plasma_thc_sheetcam with feed (1) (2).zip
- (1.38 KiB) Downloaded 58 times
- fusion_acorn_plasma.zip
- Fusion 360 Post for Acorn Plasma
- (3.83 KiB) Downloaded 61 times
Re: Post Processor Sheet Cam/Fusion 360
Update: I have used the Fusion 360 post now and it works great. My workflow is much better now not having to use Sheetcam.
Thank you Joey
Thank you Joey
New Sheetcam Rotary Post Processor. Any issues with this post please report back your findings. So we can Update this Post.
Joey,
I use the Fusion PP which is very basic. I want to mark (center punch) small holes which the Fusion post doesn't do. Does the Sheet Cam post have support for marking and possibly feed reduction for small holes? Other features not in the Fusion post?
I use the Fusion post because I use Fusion 360 CAD/CAM on my Acron cnc mill and didn't want to learn another CAM program
- CNC Control System Serial Number: (302837901215215447)
looking for help getting the post processor into fusion 360, tried downloading and unzipping it but no luck. looking for advice, thanks
Did you get this worked out? I am using the Fusion 360 post and may be able to help.
