Hello,
So long story short, I converted an old DC Knee Mill to the Allin1DC Controller. I had the machine running and cutting a part and it stopped half way through. First it gave a 425 Communication Error, then after the Y-Axis encoder stopped working. I replaced the encoder and that issue went away. I can Home the machine and Jog it around X,Y,Z no issues. However when I try to run the same program, the machine moves up 1in like the program is written to do a tool change. After I press run the machine stops and throws a 452 Communication Error. I can hear the relay connection on the board shut off when it looses connection. The only way to establish the connection again is by restarting the controller.
1. I have the supplied Shielded Ethernet cable and believe it to be working. The first time I was cutting parts I used an unshielded ethernet cable and it worked until half way so I doubt that it is any noise
2. I had centroid send me a new power supply because I measured it to be out of range although they said it was good when they tested it for me.
3. I am drawing from the 24VDC output on the power supply only for the E-Stop Circuit and Limit Switches.
452 Communication Error!!! Allin1DC ( resolved)
Re: 452 Communication Error!!! Allin1DC
hello.
post a fresh report.zip so we can view the error logs.
review this post and follow, check, and verify all the details to the letter. this post contains the most common things that cause com issues.
So I figured out the issue. I read somewhere that the crimp connection on the PSU might have a bad connection. I took out the harness and soldered the wire that were crimped to make a solid connection and now it works perfectly. Now it gives me a new error for x-axis. During the program it jumps 0.5in but it didn’t move that much so I just need to replace x/z encoders and it should be good to go.
Thanks everyone for the reply.
