Posts: 3642 Joined: Thu Sep 23, 2021 3:49 pm
Post
by suntravel » Wed Jun 22, 2022 3:27 pm
Played with macros....
Made an M55 macro to calculate Vfc for circular pockets or internal thread milling, for the case I can´t find my calculator
Replaced code with a correct calculating version and logic for senseless user input
; Filename: mfunc55.mac - To run from VCP AUX 10 key, set p197 = 5511
; M55 macro
; Description: Calculate Vfc for internal thread milling or circ. pockets
; Requires: Machine home must be set prior to use.
; Please see TB300 for tips on writing custom macros.
IF #50010 ;Prevent lookahead from parsing past here
#105=0
N100
M224 #101 "Calculate Vfc for\nint. thread milling\nor circ. pockets\n\nMill Diameter"
M224 #102 "Bore Diameter"
IF #101 >= #102 and #105 == 0 THEN GOTO 900 ELSE GOTO 110
N110
IF #101 >= #102 and #105 >= 1 THEN GOTO 990 ELSE GOTO 200
N200
M224 #104 "Feedrate Vf"
#103=#104/((#102*3.14)/((#102-#101)*3.14))
M225 #100 "Use for:\nMill Diameter: %f mm\nBore Diameter: %f mm\nFeedrate Vf: %f mm/min\n\nCalculated Feedrate\nVfc= %f mm/min" #101#102#104#103
GOTO 1000
N900
M225 #100 "Mill Diameter = %f\n can not be equal or larger then\nBore Diameter = %f\n\n Back to Start" #101#102
#105=1
GOTO 100
N990
M225 #100 "Really?\nThis will also not fit\n\nMill Diameter = %f\n can not be equal or larger then\nBore Diameter = %f\n\n Back to Start you Stupid" #101#102
GOTO 100
N1000 ;End of Macro
mfunc55.mac
(1.36 KiB) Downloaded 23 times
suntravel on Thu Jun 23, 2022 10:24 am, edited 3 times in total.
johnballard
Posts: 32 Joined: Wed Feb 19, 2020 11:49 am
CNC Control System Serial Number: 0818141095
Post
by johnballard » Wed Jun 22, 2022 8:43 pm
Humm... in your VCP I see buttons I do not have. The 45's between the X & Y jog buttons and the Axis 0 and All zero. How does the axis 0 work.
Can you share the code for them? Does the code have to be compiled into the PLC program? Do the macros also work on the real CP (aux1, aux2, etc)?
Lagunmatic 250
rk9268vc
Posts: 267 Joined: Fri Nov 13, 2020 4:12 pm
Post
by rk9268vc » Wed Jun 22, 2022 9:18 pm
johnballard wrote: ↑ Wed Jun 22, 2022 8:43 pm
He posted about it here
https://centroidcncforum.com/viewtopic.php?f=60&t=7356
and maybe in another thread as well, but cant find it
Post
by suntravel » Wed Jun 22, 2022 11:09 pm
The new buttons are in Acorn 4.79 Beta3.
Available as public download, give it a try, lots of good improvements in there
Post
by suntravel » Thu Jun 23, 2022 8:35 am
Message for first and second wrong input in a row
Post
by suntravel » Thu Jun 23, 2022 10:26 am
Next two calculators and custom VCP
Quite a good training to make such things....
mfunc57.mac
(780 Bytes) Downloaded 42 times
mfunc56.mac
(819 Bytes) Downloaded 33 times
mfunc55.mac
(1.36 KiB) Downloaded 33 times
Posts: 8952 Joined: Wed Mar 03, 2010 4:23 pm
Post
by cnckeith » Fri Jun 24, 2022 9:30 am
cool! thanks for posting.
ShaAli
Posts: 41 Joined: Mon Nov 21, 2022 12:51 pm
Post
by ShaAli » Sat Feb 11, 2023 6:19 pm
Hello, sorry for a dump question, how do I change to macro to be in inches?
ShaAli
Post
by ShaAli » Sat Feb 11, 2023 6:23 pm
mm\nBore Diameter:
change them to in ?
in\nBore Diameter:
Post
by suntravel » Sun Feb 12, 2023 2:27 am
You can edit the macros to your liking.
