Jason Hawk build / cnc retrofit
Moderators: cnckeith, Joey
repauli1
Post by repauli1 »
This project started during Covid 2020 year. It was coined the BB&S build (BED, BREAKFAST AND SHOPTIME). I designed the basic frame, mechanicals and electronics package. Jason had purchased a new local sourced cnc plasma table and quickly realized it was manufactured with very poor quality control, and never could get it to cut. After getting a refund, he opted to work with me on building his own machine. I prepared drawings and emailed them to Jason. Being a very capable fabricator he quickly built the frame. Extra touches, mods he made included capping all frame tubing, added very nice adjustable feet, added a swing out frame under table for the two 24x24x6 enclosures, added a slide in nook for his Hyprrtherm 85amp cutter, added table side covers, had frame and covers powder coated, and bedlined the 6inch deep water pan.
Jason then hauled the 3500lb frame from Oklahoma to my shop in northern Illinois (900 miles) to outfit and trim out the frame to a turnkey table, his wife and him stayed in out guesthouse hence BB&S lol. Over the next 3 days we completed the project.
The finished unit weighed in at 4,400lbs. It's a 5x10 table constructed out out of 2x6x3/16 tubing, 10ga water pan, 12ga covers. Gantry is 3x6 extrusion, with length to accommodate a 4th axis off the side. 25mm Hywin rails on Y axis, double 20mm rails on X Axis. Z Axis is a Parker with DMM Dyn4 nema 23 servo. Gantry ends, all brackets milled by my shop. Gantry plates are 19" high, 13" wide, and 1" thick 6061.
Electronics are DMM DYN4 750watt nema34 servos, 5:1 planetary gear reduction boxes, noise filter protection, 65amp line reactors. Limit switches are Altechs, the round torch mount is manufactured in my shop. Originally installed UCCNC, and MINIthc, retrofitting now with Acorn Plasma and THC.
This retrofit took place last week. My wife and I towed our 27foot Rockwood camper a total of 1900 miles, camping at four different camp grounds in route to and from Jason's shop. Had a blast!
Link to photos, more will be posted
Re: Jason Hawk build / cnc retrofit
nice! thanks for posting the photos and videos! looks great. 8-)
Joey
Plasma/Laser Lead
Post by Joey »
Slick build!
jcoldon
Post by jcoldon »
You change out that UCCNC and mini to acorn on Jason hawk build now
repauli1
Post by repauli1 »
Yes sir
repauli1
Post by repauli1 »
Updated, added 2 cut videos
AT_cnc
Post by AT_cnc »
Hi,
Nice build indeed.
I have a 4x4 Langmuir crossfire. I have decided to build a 4x8 CNC plasma cutter myself.
Would you consider sharing the 3d cad and build list?
jcoldon
Post by jcoldon »
check file section on my fb page chc plasma table builders . thers a gantry riser DXF in there that uses avid pro drive 20 deg rack . check my posts it stepper driven table it out run most servo for half the price cit like 30 k table . it all in motor and reduction drive voltage combo . i posted pic on hear also
