ShopBot RBK ReDux (or BYOB)
Gary Campbell
Post by Gary Campbell »
I have for sale a recently upgraded SB RBK control box. It reuses the Torroid DC power supply, Oriental drives and door switch. All other components are new. Control board is a Centroid Acorn 4. Comes complete with Lenovo M93 (Win10Pro, 8gb RAM, SSD), Centroid Pro Router License and setup to your system. Here is a list of the upgrades over the decade old OEM specs:
Full backplane vs partial on the OEM
Cooling fans added
Replaced "daisy chain" grounds with single point
Single power source (240AC #Amps for spindle, 110vac for router)
Added shielded stepper data cables, increased step resolution
Upgraded 24vdc power supply
Upgraded VFD contactor
VFD speed & logic harness
Fuses replaced with circuit breakers
8 inputs, 8 outputs with relays (7 with laser)
Spindle speed and logic control
JTech (type) PWM laser support
Independent dual axis autosquare support
Added "User Connection Terminals" for simplified accessory wiring
3 layer "sensor" terminals for prox homing sensors & Z (tool) setter
Translated SB user friendly macros
Centroid Wireless MPG support
NOTES: Some features listed above are extra cost. System has been tested at ~3666 steps/inch @ 1000 ipm (no load) YMMV depending on age & condition of your machine.
We no longer accept trades or exchange. As an alternative, you can send in your RBK box and have it upgraded for $1800 plus shipping. Usual turnaround on BYOB is 2-3 weeks.
Email: gcnc411@gmail.com for more information
Last edited by Gary Campbell on Mon Apr 18, 2022 9:23 am, edited 2 times in total.
Gary Campbell
Re: ShopBot RBK ReDux (or BYOB)
If you need motors, or simply would like to upgrade an older machine to newer motors, we have a set of 4 late model PRS standard motors. Model # A7328-9412KTG These are 2 amp motors with 12mm keyed shaft that require SB pinions part# 000981 (20T) for best performance. We can also custom cut shielded motor wires if you need them.
robtown
CNC Control System Serial Number: F045DA78F172-1129181385
Post by robtown »
I may have sent you a PM
Gary Campbell
robtown wrote: Wed Mar 02, 2022 5:17 pm I may have sent you a PM
Don't know if I have them enabled. Use my email: gcnc411@gmail.com
robtown
Post by robtown »
Just looking for a price on these.
Gary Campbell
robtown wrote: Thu Mar 03, 2022 12:25 pm Just looking for a price on these.
Control boxes are priced in the posts above. If you are looking for motors only, they will only be sold after this control box has been sold and the purchaser doesn't need them.
Please send email to: gcnc411@gmail.com
Gary Campbell
Buy this controller during the month of March and get the motors included at no charge!
Gary Campbell
It seems harder to sell OEM ShopBot products than I thought, so for the rest of the month of March I will be adding a Centroid Wireless MPG pendant to sweeten the deal! For $2900 you get the following:
ShopBot RBK Welded aluminum Control box, power supply and Oriental Stepper Drives. (the best open loop they sold)
4 each A7328-9412KTG 3.6:1 2amp gearmotors and motor wires
Complete Controller upgrade featuring Centroid Acorn 4 controller
Lenovo CNC-PC setup with latest version of CNC12 and Router Pro license (just need monitor KB and mouse)
Centroid Wireless MPG Pendant (with user selected macros installed)
Gary Campbell
Re: ShopBot RBK ReDux ( **REDUCED**)
Our swapover to servo controllers is virtually complete. This RBK model is the last stepper based controller in the shop, and I'm dropping the price to make room for other systems.
Controller, CNCPC (fully setup with Pro license), gearmotors, motor wires now for $2250. Add in a wireless pendant for $2550 (all plus shipping)
Gary Campbell
Sold pending receipt of funds
****SOLD*****
