SIMODRIVE 611 system on VMC
I have a Cinncinati 1250 VMC with bad Acramatic A2100 control. The drive system that works is a SIMODRIVE 611. All servo motors Encoders are present. The machine is also equipped with Renishaw probe and tool setter. Is a Cenroid product available to interface to my machine?
Re: SIMODRIVE 611 system on VMC
There are various models of SIMODRIVE 611. Even if you have a "universal" model, I will say no, it will not interface. The drive needs a single ended -10 to 10V analog speed request input or differential quadrature position request input. In my quick search of the manual, I did not see either of those.
https://cache.industry.siemens.com/dl/f ... 510_en.pdf
- CNC Control System Serial Number: 0008DC111213-1202201060
you can use an OAK controller and change out the encoders and run the simodrive 611. I've done it on mine and it works just fine.
