ShopSabre Sidekick 10 Acorn Retrofit
Moderators: cnckeith, Joey
jcoldon
Re: ShopSabre Sidekick 10 Acorn Retrofit
Post by jcoldon »
My key pad works fine my z pg up down and arrows all work
jcoldon wrote: Tue Jan 18, 2022 8:52 pm My key pad works fine my z pg up down and arrows all work
Jeff, please post a current report from your machine so I can see some of the parameters.
Joey
Plasma/Laser Lead
Post by Joey »
Hey Jeff. A report is pretty much a snapshot of your Acorn system settings. Heres a video on how to create the report. It's pretty quick and easy
jcoldon
Post by jcoldon »
ok report hear you go
report_0035FF9713B5-0716214937_2022-01-18_21-59-45.zip
(2.34 MiB) Downloaded 53 times
jcoldon
Post by jcoldon »
i think this z axis issues it a clear path motor problem wiring wise bob seams to be having this problem im running steppers gecko drives no problems
jcoldon wrote: Sat Jan 22, 2022 3:58 pm i think this z axis issues it a clear path motor problem wiring wise bob seams to be having this problem im running steppers gecko drives no problems
Could you please clarify what you are saying here?
repauli1 wrote: Sun Jan 23, 2022 7:50 pm Here is a video link I sent Keith, that was Friday, I spent 4hrs rewiring to diagram 14972 dated 1-21-22 today, still have same issue. I am going to send in new report and findings tomorrow.
Link to my issue:
Warning: Poster, Album not found for https://photos.app.goo.gl/wgDPaCUj4DNV8rtF7. Please check the URL by editing the post and try again.
bob needs help with wiring the clearpath drive fault signals.
to help out we drew up and tested this $8 relay board.
https://amzn.to/3FRhAhL
here is the new clearpath schematic using that board
https://www.centroidcnc.com/dealersuppo ... 972.r6.pdf
jcoldon
Post by jcoldon »
why do you need all the extra wiring for drive ok.. just wire enable line this is plasma drive fails no big deal. all will stop any way or jump teeth on the reduction drive if master and slave has problem. extra wires in plasma just cause trouble we not using them on steppers believe me my steppers bend my gantry
I just installed the latest beta, R13277, and ran the calibration. So far so good.
With my Clearpath motor on the Z axis I lowered the RAS setting from the default 40ms to 9.8ms to not fight with the THC PID and re-tuned the motor. Not sure if I need to do this with the X and Y motors or not. More testing tomorrow after lunch.
The bug that would not allow me to import my "drive type" is fixed. Saved a lot of setup time by doing this. Manually setup all other parameters.
Still a keyboard issue with the page up and page down for the Z axis. When I press either page up or page down the Z does not move and the message in the message window says "please select an axis".
If I open a large PDF file and set it to a full page and press page up or page down it works just fine, the PDF advances or backs up one page. Am I the only one with this issue? Why does the page up and page down work as it should in other programs? Why does CNC12 ask me to select an axis? Oh, and it goes into incremental mode at the same time.
If I turn off keyboard jogging with ALT-J and press the page up or down I get the message "press ALT-J to enable keyboard jogging".
The X and Y axis work just fine from the keyboard. I'm gonna try another keyboard tomorrow.
report_80F5B52C3273-1028215302_2022-02-01_17-43-12.zip
(1.7 MiB) Downloaded 62 times
After calibration I cut the Centroid "test hook" and it came out good. To my surprise it cut the 1/4" holes and they look great. A bit more dross on the back that I would like but I can tweak that away. More testing tomorrow, after I install the newest beta that Keith just sent me. :mrgreen:
Here's a link to my updated album with pics of the test hook.
