Im sure there is an easy answer but I just want to triple check which schematic I'm using for that driver? Doing some pre-wiring before it arrives. Thanks all!
Nate
Which Schematic for DM860T
- CNC Control System Serial Number: e062346fe6b5-1207215421
Re: Which Schematic for DM860T
Anyone at all? I appear to have gotten there new "digital" version. Im sure its a lack of knowledge of what to read about/search for just a nudge in the right direction would really be appreciated. Is there a guide somewhere speaking to how to set the pulses/rev, and given my motors are 5a Im assuming I use the 5.14a peak current setting?
Connect to the DB25 header and use the LeadShine schematic that shows that. Ignore the "BRK" & "ENA" terminals to test
5.14 peak would be my choice (or 1st one below)
set step resolution to either 1600 or 3200 and match in Acorn Wizard
