New STEPPERONLINE Integrated Servo motor
dtananko
CNC Control System Serial Number: 5462
Re: New STEPPERONLINE Integrated Servo motor
Post by dtananko »
Keith, yes, I started with WorkBee and upgraded it to QueenBee. It is HUGE improvement in terms of smoothness of motion due to linear bearings instead of rollers. Here are some pics. As you can see I cannot fit anything bigger than 8mm lead screws.
I studied Franco (and Marty's) channel very closely and watched all WorkBee videos. He ended up putting ClearPath motors in it and getting reed of it. LOL.
Best Regards,
Dmitry
8mm pitch screws would be 0.315" per rev.
thanks for posting photos that helps alot!
make a fresh report.zip and post here as well
dtananko
Post by dtananko »
Here is the report. THanks.
report_80F5B5F53BBF-1216215462_2022-01-14_18-05-16.zip
(156.27 KiB) Downloaded 63 times
Best Regards,
Dmitry
dtananko
Post by dtananko »
Sorry, it took some time to write the file. Here is the better one.
(628.9 KiB) Downloaded 70 times
Best Regards,
Dmitry
ok great. got better photos of the gantry screws? are these double lead screws?
with power off, tape and tape/ruler to the axis and line it up with the slide, mark the screw with a marker and grab the screw with your hand rotate it one revolution and then how far did the slide move?
dtananko
Post by dtananko »
It is 8 mm move per revolution confirmed.
Best Regards,
Dmitry
great! that will work nice with 3D surfacing and our G code smoothing feature.
what kind (make/model) of stepper drives are currently being used? photos?
related in case you haven't seen this post.
https://centroidcncforum.com/viewtopic.php?f=57&t=3021
Sword
Post by Sword »
To really pull out the detail, you need to get familiar with the "Smoothing" settings I speak of in that thread. Along with that, try adjusting your accel setting (currently 0.5) in the wizard, but you can also tweak it in the smoothing settings, where you should set one up specifically for 3D relief work. With 3D files, your Z axis is consistently being jerked up/down and if your accel is set to be too abrupt, steppers can loose steps.
Also, make sure you set the Z axis feedrate to be the same as your XY. This will help with motion flow, in that the XY won't have to wait for the Z so much.
Next, and this is more for getting an opinion from the others here, but wouldn't putting ClearPath's on a acme screw driven machine be a bit much overkill? If you want closed loop, while not as sexy, how about a set of NEMA23 closed loop steppers/drivers. Although, it is fun spending other peoples money! :lol:
Scott
