Acorn for DIY CNC cam grinder on CNC lathe
Re: Acorn for DIY CNC cam grinder on CNC lathe
cncsnw wrote: Sun Jan 09, 2022 1:57 pm On the other hand, a person who know what the cam profile is supposed to be, and is moderately proficient with a spreadsheet, ought to be able to cook up their own CNC codes without requiring any CAD software at all.
Isn't it is just a long list of points, with X coordinates varying through a succession of C angles?
Yes it is
vw_chuck
CNC Control System Serial Number: 0035FF8FEB5F-0708203490
Post by vw_chuck »
I see like everything it is never easy. Yes I may be easier to just code this by hand.
firebrick43
Post by firebrick43 »
suntravel wrote: Sun Jan 09, 2022 1:09 am Setting up the spindle as C-axis with the grinder on X should work. If the center of the grinding spindle is on the same height with the C-axis change in diameter of the grinding wheel will not change the cam profiles, only the size which could be easy dialed in after dressing the wheel.
A cam can not be on the center of the wheel during the lift portion/closing portion, its geometrically impossible.
firebrick43 wrote: Thu Jan 13, 2022 12:03 pm
Have a look at the drawings here:
http://www.metallmodellbau.de/Nockenwel ... schine.php
vw_chuck
Post by vw_chuck »
Uwe that is a crazy machine. Serious amount of time went into it. I was also thinking just making a replicator machine like yours but with another wheel the same size as the grinding wheel that follows the original camshaft lobe. No idea if it would work or not. Thanks for the link.
Here one of the best old engine engeneering books, but sorry also only in German:
http://www.eurospares.com/graphics/engine/Apfelbeck.pdf
Alone the drawings could be helpful to build your own camgrinder, ore something to scan the coordinates for CNC.
firebrick43
Found my WOPS manual. Here is a few good pictures showing how the lift portion of the cam is above/below the center line of the wheel and the second shows how wheel diameter changes as dressed changes the geometry of the cam unless there is a program (such as WOPS) that makes compensations for it.
bbox
Post by bbox »
I have seen a fellow machinist do the following, but it will require use of Z axis movement and a toolpost grinder for the CNC lathe:
Grind a slight taper on the trailing edge of the grinding wheel.
Touch off as usual on the flat un-tapered part of the wheel
Move the z axis away from the wheel and and dial in the depth of cut you want
Advance the grinding wheel on the z axis and grind, retract, reverse, reset and repeat.
The idea is that the tapered portion of the wheel does most of the grinding, leaving the flat part to hardly grind at all preserving the precision needed. Eventually, the wheel wears and the flat part is worn off, so you must re-dress again.
SuburbanTool Inc has some superb YouTube videos.
Bill
